Electrical Question?? I've narrowed it down.
Old June 24th, 2018, 06:35 PM
Kensey's Avatar
Hi all.
I have a 72 Delta 88. My dash & flood lights are not working. Glove box, dome and curtesy are good. I've checked the bulbs, good. I tested all the fuses at the fuse box, everything is getting power EXCEPT the fuse with the dash & flood lights!
I'm not an electrical guy.. What's my next move? Bad headlight switch, that would turn the dash & floods on. OR something at the fuse box?
Any thoughts would be VERY WELCOMED!
thanks,
Kensey
Pittsburgh, PA
Kensey is offline
Old June 24th, 2018, 06:51 PM
The small fuse for the dash lights only has power when the lights are on. Double check the tail light fuse and see if you have tail lights.
Old June 24th, 2018, 07:50 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Please define floodlights? Do you mean parking lamps? You are saying that there isn't any power on either side of the dash light fuse? If true check the bulkhead connector on the firewall. Google 72 GM Bulkhead connection for a look at that. Also, verify all grounds. Wiring diagrams are available for purchase online. Order yourself a hard copy as the online versions are hard to read.
droldsmorland is offline
Old June 25th, 2018, 06:22 AM
Kensey's Avatar
By flood lights I mean the small lights that light up the radio, wiper controls etc. Same circuit also lights up the speedometer and gas gauge. Those are not working either.
I did test the fuse with the light switch on, and power on at the key.
Neither side of the fuse is getting power. All others are getting power.
Thanks for the help!
Kensey is offline
Old June 25th, 2018, 06:28 AM
Did you look to see if you have tail lights? Is the instrument light potentiometer turned all the way CCW?
Old June 25th, 2018, 07:42 AM
Kensey's Avatar
Tail lights are fine. Also, aren't those are on another circuit?
The potentionmeter is all the way up.
My concern is that there is not power to the fuse. That's weird??
Kensey is offline
Old June 25th, 2018, 07:51 AM
I don't have a schematic for your car. I'm assuming the light circuit is the same as an A body. The taillight fuse provides power to the light switch taillight and panel lights. The little 3A fuse is powered when the panel lights are on. All indications point to a problem with your headlight switch.
Old June 25th, 2018, 09:18 AM
Kensey's Avatar
It's weird, the light switch works for the headlights etc, and turns on the interior curtesy lights. So is it possible that JUST
Kensey is offline
Kensey's Avatar
The dash lights trip is not working? I guess anything is possible, but is it likely?
Thanks again all.
Kensey is offline
Old June 25th, 2018, 09:40 AM
The headlight switch has different circuits in it. The courtesy light circuit provides a switched ground to turn on the lights.
Thanks again all.
The dash lights are controlled by the rheostat on the front of the switch, I suspect therein lies your problem. You can jumper 12v to the 3A fuse that feeds the dash lights and they should come on.
The parking light issue has to be internal to the switch also as both your headlights and tail lights work.
This should be a breakdown of the headlight switch:
Old June 25th, 2018, 04:47 PM
cjsdad's Avatar
I recently had a similar issue with mine while replacing my gauges. The dash light brightness is controlled by the rheostat in the light switch and that can become very oxidized over time. It may not actually be corroded but covered with dust and oxidation and stop working. Mine would not even turn the courtesy lights on because of so much dust build-up. Take the light switch out and clean it well with a toothbrush and electrical contact cleaner. Or just replace it. You can also try turning the dimmer back and forth for a few minutes and see if that helps. Sometimes that will clean the contacts enough to work.
cjsdad is offline
Old June 25th, 2018, 05:15 PM
Yellowstatue's Avatar
Flood lights are the interior lights that flood the vehicle with much needed light when it is very dark outside or inside at night.
Yellowstatue is offline
Old June 25th, 2018, 05:29 PM
Kensey's Avatar
OK, I did the jump wire and my floods, speedo light and etc lit up!
Would this mean it is the light switch for sure? OR are there several things that could be keeping power from the fuse in the box? I'll replace the light switch for sure, I'm just asking so I don't get my hopes up too high.
Kensey is offline
Old June 25th, 2018, 06:11 PM
I suspect the headlight switch, but... Lets do one more test, you need to remove the switch and jumper terminal 5 to terminal 2 on the switch connector. If the dash lights come on the replace the switch. Cleaning them works for a while if the rheostat isn't open, but it will act up again.
Old June 25th, 2018, 06:50 PM
We had another name for those lights and the dome light in the 70s.
Old June 25th, 2018, 07:41 PM
jaunty75's Avatar
The factory service manual actually calls them floodlamps.
jaunty75 is offline
Old June 25th, 2018, 08:02 PM
cjsdad's Avatar
I can see paradise by the dash board lights!
cjsdad is offline
Old June 26th, 2018, 07:53 AM
Kensey's Avatar
Picking up a new headlight switch today. Figure I should have one ready once I pull the old one out.
ONE MORE random question. My car has not been hacked apart by any means, but has had some word done over the years. There is one wire that I'm not sure what it goes to, I can't find it on the wiring diagram in the OG manual.
It's red, and has a small in-line fuse. 5 amp max. Someone decided to strip the end of the wire and piggy back it into another fuse at the clip. Is this for the radio? (Which is currently not working.)
The plot thickens right... I figure this red wire has nothing to do with my flood lights though. Same issue with that wire hooked up and disconnected.
Thoughst?
Kensey is offline
Old June 26th, 2018, 08:59 AM
cjsdad's Avatar
That does sound like a radio feed wire if you have an aftermarket stereo. Some stereos have the memory feed wire as red with the ignition feed as yellow and some use the opposite. You would need to check the requirements for your stereo to know which you have. Some stereos will work without the memory feed wire hooked up but will lose clock and station preset each time the ignition is turned off and some will not work without both feeds connected. Again, you would need to find out what your stereo needs.
cjsdad is offline
Old June 26th, 2018, 11:38 AM
Kensey's Avatar
Stock AM radio... keepin' it classy!
Kensey is offline
Old June 26th, 2018, 12:40 PM
It may be an aftermarket alarm, or any other accy that may have been added in the past.
Old June 26th, 2018, 02:00 PM
Kensey's Avatar
I'll try to follow it when I remove the light switch.
Kensey is offline
Old July 4th, 2018, 06:40 AM
Kensey's Avatar
Ok, here's my update.
Put in a new headlight switch. Flood lights come one, won't turn off... They'll dim by turning the ****, but not shut off when the switch is pushed all the way in. I think the switch may be junk, gonna exchange it today just to eliminate the possibility.
TWO NEW QUESTIONS:
What the hell is this??
And second, I followed the red wire with the in-line 5 AMP fuse that is just inserted into the fuse box. It come out of a connector, that leads to a thick black wire that seems to come from the steering column. Ignition switch?
Thanks all again for your help on this!
Kensey is offline
Old July 4th, 2018, 08:18 AM
cjsdad's Avatar
The black box and four-wire connector are part of an aftermarket Dana speed control unit, "cruise control". I suspect the wiring that the fuse holder is part of is also part of the Dana wiring. The On/Off switch should be on the turn signal stalk of your steering column, that is why the power feed wire is routed to the column. If it is not working I may be able to help you troubleshoot it. It should not cause electrical issues as long as it was installed correctly. Sounds like it was not installed cleanly, but it may still be connected correctly. I know that sounds contradictory but it can be connected right but still be a sloppy install. If everything is still there, it may be repairable.
The four-wire connector is for speed controls like "set", "accelerate", and "cancel". The other wiring is for power, brake light, speed sensor, engine speed sensor and such.
cjsdad is offline
Old July 4th, 2018, 08:28 AM
cjsdad's Avatar
Oh yeah, if your dash lights won't turn off after the new light switch was installed, you either have a bad switch or you have power feeding back into your lighting circuit somewhere else. You're gonna have to check as much of the grey wiring connections as you can find behind your dash. You should have connections at the glove compartment, ash tray, all of your flood lights, the instrument panel. There should also be at least one spare connector under the dash for extra connections. Make sure there are no connections between the Dana control module and that grey wire. That grey wire is often mistaken for a black ground wire by aftermarket electronics installers!
cjsdad is offline
Old July 4th, 2018, 08:43 AM
Kensey's Avatar
I don't plan on using cruise control anytime soon, can I just disconnect it?
I got a new, new light switch I'm going to install now. (In 94 degree weather...)
ALSO, when the last switch was installed the parking lights would not turn off either. I forgot to mention that.
Thanks!
Kensey is offline
Old July 4th, 2018, 09:32 AM
cjsdad's Avatar
You can disconnect the power to the cruise unit and it will remain inactive. If you try to remove it, you will need to remove everything down to the wire connections and actuator. All or nothing kinda thing.
I did some looking at the wiring diagrams on-line for Dana products and some do tie into the lighting circuit so follow all of the wires from the cruise unit (there aren't many of them) and see if any of them are connected to the grey wire for your dash lights. If it is, disconnect it and see if that will resolve your lighting issue.
cjsdad is offline
Old July 4th, 2018, 09:33 AM
Kensey's Avatar
cjsdad, THANK YOU for all of your help/research on this! Gonna look at it now.
Kensey is offline
Old July 4th, 2018, 04:12 PM
Kensey's Avatar
AHHHHHHH HAAAAA!!!!!!
My new light switch was bad right out of the box. 2nd new switch installed, all is right with the world! I can see my vitals at night.
THANKS AGAIN ALL that offered help. This forum is priceless for that very reason.
Kensey
Pittsburgh, PA
Kensey is offline
Old July 5th, 2018, 07:58 AM
Good it worked. That 4 wire plug is, like said above, probably part of that Dana unit. That plug is computer hardware format, used to be used for CD drives and hard drives and fans, but now has been replaced by a newer format for everything but fans. It's 12V.
Koda is online now
mmitton
July 22nd, 2018 01:11 PM
Eastflorida
August 20th, 2017 04:30 PM
cecilsclassics
April 17th, 2015 09:56 AM
zodiacblueS
May 26th, 2012 03:40 PM
hookem horns
November 6th, 2011 06:45 PM
Quick Reply: Electrical Question?? I've narrowed it down.
