Installation fan controller
Old April 24th, 2018, 11:05 PM
Haidda's Avatar
Hello guys, what is the ideal way to install the fan controller (see picture)? Stick it through the radiator or put it in the hose? When I stick it through the radiator, does it measure the right way because of the airstream while driving? When I stick it in the hose i´m afraid to damage it, because it is filled with gas?
Thank you for your tech tips
Daniel
Haidda is offline
Old April 25th, 2018, 04:31 AM
Most install it here, the fan is mainly required at very low speed or idle. When the car is moving there is enough airflow to cool without the fan.
Old April 25th, 2018, 06:54 AM
Haidda's Avatar
Thank you, will try that
BR
Haidda is offline
Old April 25th, 2018, 07:37 AM
I've used that style controller before. The bulb is supposed to be in the coolant flow in the radiator hose. There is supposed to be a rubber "wedge" that sits on the hose barb on the radiator and has a groove for the capillary tube so you don't crush it when you tighten the hose clamp.
joe_padavano is online now
Old April 25th, 2018, 08:54 AM
That style can be installed either way Joe. If your using the contact method, it needs to be installed against the radiator close to the top hose.
Bee Saint Louis
July 5th, 2019 08:58 PM
Dan Wirth
December 2nd, 2011 12:55 PM
69350rocket
December 27th, 2010 02:15 PM
TRAIN RACING
November 5th, 2010 01:02 PM
Jolly Green
May 17th, 2008 05:04 PM
Quick Reply: Installation fan controller
