371 Engine Ticking
371 Engine Ticking
Hello All, I was interested in anyone's thoughts on what could be the cause of the ticking noise in my 371 motor, The engine has just turned over 100,000 miles.I changed the oil about 8 to 9 months ago and just recently the motor has started to make quite a loud noise like a tappet etc, Its fine when i start and drive the car for about ten minutes then it will start to get loud, it's like a really loud ticking, not a bang or clunking noise. .If i keep driving after 2 or 3 miles the noise will slowly go away? Its done this to me twice in the last couple of months, Was just wondering if anybody had any thoughts as to what it may be and to what i should look out for, Many Thanks In advance for any replies, All the best, Ray.
First off how many miles have you put on the car in that 8 or 9 months ? If it is a lifter (pretty common) a oil and filter change may clear it up. A shot of Marvel Mystery Oil in the oil wouldn't be a bad idea ether. I would do that first before I started pulling the valley cover and intake and such off the engine. That may be the cheapest and most common fix. Once I switched to Rotella 15- 40 my lifter problems have disappeared, I feel the high detergent factor and frequent oil changes has helped eliminate that issue in my car.
With 100,000 miles how is the oil pressure cold and after a warm up? Is there a big difference from cold to warm at idle?.... Tedd
Hello Tedd and Sugar Bear, Thanks for your replies, I have talked to the Guys here at Penrite Oils, They have recommended 20w/60 Classic lite. They tell me that is a very popular oil for classic car buffs, Ill keep you posted as to the issue with the tappets and will post some pics of the car, Once again , many thanks for your input, Ray, Brisbane.
You oil guy probably knows a lot more about his oil than I do but 20-60 seems pretty heavy. I would have concerns about the use of that thick of oil on cold startups. Then again 100,000 miles is quire a lot for a 60+ year old car it could have major clearances every where. Your call... Tedd
I agree with Tedd, 20-60 is heavy, I would have an oil pressure gauge in the car myself just in case the engine hasn't loosened up to handle the worst case 60 viscosity.
Also as Tedd mentioned..If its a lifter tick, it may clear up after a couple oil changes.
I think it stays warm down in Australia does it Ray ?
I hope you have good luck with the oil.
gibbo69olds
October 3rd, 2007 06:39 AM
