Door lock cylinder
Old September 29th, 2017, 01:41 PM
JLane92's Avatar
Door lock cylinder
What is the easiest way to get this cylinder out. Its in a 71 Cutlass
JLane92 is offline
Old September 29th, 2017, 01:43 PM
JLane92's Avatar
JLane92 is offline
Old September 29th, 2017, 03:34 PM
VI Cutty's Avatar
You have to remove the red spring retaining clip. Put a large flathead screwdriver between it and the lock cylinder and twist/lever it off.
The lock cylinder will then pull straight out.
VI Cutty is offline
Old September 29th, 2017, 04:07 PM
JLane92's Avatar
I got it thank you. Now if I can figure out how to finish wiring this hei and mad box I might be able to get it running in the next couple days
JLane92 is offline
Old September 29th, 2017, 06:51 PM
VI Cutty's Avatar
I can't help you there, but others around here sure can. Might be worthwhile posting in the engine board to get the right eyes on it. Good luck!
VI Cutty is offline
Old September 29th, 2017, 07:17 PM
JLane92's Avatar
Thank u again
JLane92 is offline
1Fastolds
Ninety-Eight
April 2nd, 2016 06:51 AM
goldie442
August 21st, 2015 11:01 AM
benjamin247
October 1st, 2014 07:23 PM
Maverick
Transmission
April 22nd, 2014 05:04 AM
randomarrival
December 22nd, 2012 12:28 PM
Quick Reply: Door lock cylinder
