Shifter Linkage
Shifter Linkage
Hi All!
I have a column shift car that originally had a metal rod linkage that went to a jetaway. I swapped out for a TH350 and we are working on finishing touches. I noticed that there is a metal shaft that attaches to a bracket that is attached to the frame under the drivers side next to the shifter mechanism on the transmission.
There seems to be a ball type connector that slips into the bracket that is not on the linkage I have. Does anyone know where I can get that piece that slips into the bracket? Also, will this same shifter linkage work with the TH350 as it did with the Jetaway?
Here are a couple pictures...
Thanks!
Bryon
Bracket on frame (left side) across from shifter lever (on right).
Column shifter linkage
Thanks!
Bryon
Last edited by 1968CutlassSupreme; September 23rd, 2017 at 08:02 PM. Reason: Added Pictures
Joe,
Could I not just replace the original linkage with something like what is shown here at this website?
http://www.honestcharley.com/hot-rod...0-400-700.html
Thanks!
Thanks!
Joe,
Thanks!
Thanks!
Seriously, you have all the parts now except for the little "U" bracket on the trans. Nothing will work better than the stock parts.
Thanks.
Secondarily, and I sincerely hope this does not seem rude, but I can't help but notice you have ignored all of my questions about the power steering bracket. Is that deliberate? I thought you offered to find and send me the bracket I need for the cost of shipping. Maybe I misunderstood.
Bryon
