The new FiTech injection works great!
Old May 23, 2017 | 06:40 AM
Gary M's Avatar
Fitech distributor answer
This is the response I got to my question about what dist to use and if a pertronixs 3 would work. I asked if they had any recommendations as far as distributor.
"Hi Gary, in order to use the timing control the distributor must be a 2 wire
magnetic pick up type. We have had good luck with MSD distributors."
Mario De Leon
Technical Manager
FiTech Fuel Injection
Old May 23, 2017 | 07:02 AM
Interestingly, the only distributor Summit lists which is computer control compatible is the FAST 305018.
https://www.summitracing.com/search/...0%2B4294930064
The MSD distributors have one with vacuum advance and an additional one with mechanical advance only:
https://www.summitracing.com/search/...44559%2B400122
It was my understanding that in order to use a distributor with the EFI system the advance had to be locked out completely...
I would contact FiTech before purchasing a system. I would definitely want a definitive answer on what distributor provides timing control.
Old May 23, 2017 | 07:15 AM
Gary M's Avatar
My original question to Fitech
"I have a 1972 cutlass with a 455 motor. Mild cam and auto transmission
presently ( to be changed to manual transmission later).
I understand you have a unit that controls the distributor. My question is
will your unit control a billet distributor with a pertronixs lll unit in
it? Do you have a suggestion as far as what distributor to use?"
I looked at multiple vendors also trying to find a distributor that can be computer controlled and finally asked Fitech.
You may need to ask Fitech for specific distributor brand and part number to get the right one.
Old May 23, 2017 | 07:33 AM
Apparently, FiTech also mentions that the distributor must be phased:
https://www.summitracing.com/parts/msd-84211
Old May 23, 2017 | 09:24 AM
Gary M's Avatar
Side note
One more thing, I read somewhere a thin metal plate may be needed between the "stock" intake and Fitech carb. To prevent vacuum leaks. Looking for that source again to post here. BRB
Old May 23, 2017 | 09:28 AM
Gary M's Avatar
Quote from Fitech question and answer website
"You need a 2 wire distributor ‘locked out’ ( this is easily done on MSD or equal distributors) like Summit or Jegs brands."
Old May 23, 2017 | 09:29 AM
midnightleadfoot's Avatar
ph_ckstick1
Originally Posted by ART T
I bolted a 600 hp unit onto my stock 64 manifold and I needed a 1/4" spacer so the carb linkage would clear the manifold.
So far I've seen all the 4 barrel tbi's working better with a spacer or the divider in the intake milled down.. have not seen dyno pulls with a factory q jet intake yet.. but the dual planes with solid divider have fueling issues.. And milling the divider some fixes the a/f issues to some cyl. and picks up some power to boot..
Old May 23, 2017 | 09:36 AM
You mean milling this part of the intake?
It's interesting that a single plane manifold runs better than a dual plane manifold.
Anyone else hear about this?
Old May 23, 2017 | 09:50 AM
ph_ckstick1
Single planes ?? yes on multi port efi..
on the tbi you mill the divider a little,, not hog it out
Old May 23, 2017 | 12:39 PM
Gary M's Avatar
Took me long enough to find it but here it is
a poster on the facts and answers at Fitech.com
"I have spread bore intakes {quadrajet style] will it bolt up or do I need an adapter"
Bryce - FiTech Tech Pro October 13, 2016 at 3:16 pmReply The FiTech throttle bodies will bolt to a spread bore intake. They might not seal properly so you may still need an adapter.
Old May 24, 2017 | 05:47 AM
JSPajak's Avatar
http://realoldspower.prophpbb.com/topic9853.html
19+ pages of experiences there.
Old May 24, 2017 | 12:59 PM
Gary M's Avatar
EDIT: This adapter did not work due to butterfly interference with the FiTech.
Jegs<br/>Weiland adapterWeiand 9006
Carburetor Adapter Square Bore Carburetor to Spread Bore Manifold part # 925-9006
Going to try this one because its only 1/16 thick. DOES NOT WORK. BUTTERFLY INTERFERENCE.
Old Jun 20, 2017 | 04:09 PM
RetroResto's Avatar
I tried that adapter.. too thin. It didn't work for me on my 350.
Old Jun 20, 2017 | 06:06 PM
Gary M's Avatar
Did it leak or was there another problem with it?
Old Jun 20, 2017 | 06:27 PM
RetroResto's Avatar
I had butterfly clearance issues with my fitech trying to use it with a spread bore manifold.
Had to go with a 7/8 adapter to make it work.
Unless I was missing something I can't see how it would work with factory intake?
Old Jun 20, 2017 | 06:37 PM
Gary M's Avatar
Interesting. It's listed as a spread bore/square bore adapter. Do you have the OAI hood? If so does the foam air cleaner fit right with the 7/8 adapter?
Old Jun 20, 2017 | 06:54 PM
RetroResto's Avatar
No my hood is just an S hood.
I used the spacer from speedway motors.
http://www.speedwaymotors.com/Univer...lQuery=1351932
If you have a square bore intake ( as in holley will bolt on) you are fine, and will not need any adapters.
I used a Tanks inc. Fuel tank with in tank pump.
I'm happy with the unit so far. I have only put on about 400 miles, and there a few fine tuning issues I need to make but otherwise its great.
Old Jul 13, 2017 | 06:50 AM
  #58
RetroResto's Avatar
I was curious if you ever put the fi tech on?
Old Jul 13, 2017 | 03:48 PM
  #59
Gary M's Avatar
I haven't
I've been working 80+ hours per week lately.
Old Jul 13, 2017 | 04:03 PM
  #60
RetroResto's Avatar
80 hours doesn't leave much time for fun.
sure does help in the Cash dept. though
Old Jul 14, 2017 | 02:12 AM
  #61
bw1339's Avatar
What improvements are you seeing?
Old Jul 17, 2017 | 01:59 PM
RetroResto's Avatar
Possibly near the top of my list would be the warm starts! Bump the key..
But I would have to say all starts are improved.
Much stronger and responsive throttle response.
I'm sure these can all be achieved with a good carb too, but that's something I didn't have.
Old Jul 17, 2017 | 05:57 PM
  #63
Gary M's Avatar
That quick start makes a big difference. I hate the cranking the old cars need to start. Does it sound about the same or stronger? I can't wait to get one on my 455. Don't remember, can you now use regular unleaded instead of the premium gas?
Old Jul 17, 2017 | 07:06 PM
  #64
RetroResto's Avatar
I should mention the sound is heavy vacuum, if i am at 1500 rpm and kick it down on the road it's distinct sound I love it! And the response. It resembles a modern car.
I'll be honest I have run 91 octane all the way down to 87. I did NOT notice a bit of difference. I read on the Chevelle forum where a guy was running E85
richkidd24
Jun 3, 2016 02:53 PM
ohiocutlassparts
Dec 10, 2013 02:54 PM
Oldssupreme
Jan 10, 2013 07:35 PM
coppercutlass
Dec 31, 2012 04:02 PM
BlueBlock350
Apr 9, 2008 10:38 AM
