DX block sonic check results
Old August 26th, 2015, 07:25 AM
chadman's Avatar
Here is the sheet from a block I had checked. The thinnest spots are highlighted. Just FYI.
chadman is offline
Old August 26th, 2015, 07:32 AM
wr1970's Avatar
So what bore will you be using now you know that two cylinders have less material than the rest.
wr1970 is offline
Old August 26th, 2015, 07:37 AM
chadman's Avatar
For now it's just going to be oiled, bagged and tucked under the bench for the future nitrous motor build. I will probably bore it to 4.155 when the time comes. That leaves me meat to go 4.165-4.185 in the future if need be. BTW this was checked at the standard 4.057 DX bore.
chadman is offline
Old August 26th, 2015, 07:44 AM
ELY442's Avatar
Can block filling help?
ELY442 is offline
Old August 26th, 2015, 07:55 AM
chadman's Avatar
It will be filled to the water pump holes regardless for what I'm doing with it. The thinner spots aren't an issue and are not abnormal at all for one of these. I'm fine with it.
chadman is offline
camshaw
June 23rd, 2015 04:55 AM
Bernhard
December 13th, 2012 07:22 PM
64Rocket
March 1st, 2012 07:45 PM
smcurro
February 18th, 2009 11:21 PM
Quick Reply: DX block sonic check results
