330ci bored .30 over
Old Sep 20, 2013 | 10:42 AM
Racing Palm Tree's Avatar
In preserving my 330ci engine, I would like to get a little more power by boring it .30 over, but I hear getting pistons can be qutie expensive or impossible. Can someone assist me in understanding this topic more in detail?
Can i bore the 330ci .30 over?
What size pistons will I need?
Which brand yeilds the best results in the piston catagory?
Approximatley how much more HP can I get by boring .30 over?
Old Sep 20, 2013 | 11:10 AM
Oldsmaniac's Avatar
The 330 can go .030 no problem and beyond. EGGE Machine has pistons at a reasonable cost. Not much HP gain at all going from a stock 330 to an .030 overbore.
Old Sep 20, 2013 | 11:19 AM
coppercutlass's Avatar
Chevy budget Olds powered
I have been told you can bore the 330 to fit std 350 pistons.
Old Sep 20, 2013 | 01:49 PM
So whats the most that I can bore this block? And whats the best pistons?
Old Sep 20, 2013 | 02:03 PM
You can go up to .060 safely, others may pipe in and say what pistons they used.
Old Sep 20, 2013 | 06:21 PM
BILL DEMMER's Avatar
Just the facts...
iirc, you may need slipper-skirt pistons when you bore a 330 out to 4.057" (std. 350 bore).
bill
Old Sep 21, 2013 | 05:31 AM
cutlassefi's Avatar
bill
Huh?
If I were you I'd bore it to 4.00, offset grind the crank to 3.500 and use 350 Chevy pistons with SBC Rods. Lighter, stronger and a whole bunch of options. Rods and pistons are reasonably priced as well.
Jmo.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
Mr.Cutloose
Oct 4, 2010 09:53 PM
70 cutlass s
Dec 22, 2009 10:22 AM
HouTXCutlass
May 10, 2009 07:56 AM
four42
Mar 29, 2008 11:56 AM
