skipping problem
Old July 28th, 2013, 06:43 PM
brandon 455's Avatar
skipping problem
I just installed new plugs and wires on my Cutlass. Somehow when I was putting them on I ended up developing a dead spot at cruising speed. I've checked my plugs and wires along with the distributor cap and rotor. What else could it be?
brandon 455 is offline
Old July 28th, 2013, 06:57 PM
brddg's Avatar
Crossfire? Route plug wires 5 & 7 in opposite directions around the distributor and see if that helps.
brddg is offline
Old July 28th, 2013, 07:00 PM
Okay ill give that a shot tomorrow. Could you explain how cross fire happens?
Old July 28th, 2013, 07:24 PM
brddg's Avatar
When cylinders that are next to each other fire in succession the spark energy can "jump" from one wire to the other and cause a misfire in that cylinder. I have heard that the cylinder pressure causes increased resistance in the plugwire but it's really a moot point if it gets fixed.
brddg is offline
Old July 28th, 2013, 09:38 PM
Okay that makes since
Old July 29th, 2013, 07:02 AM
Make sure all your wires are seated properly at the distributor and at the plugs. You also could have gotten/ or cracked a plug.
oldcutlass is offline
Old July 29th, 2013, 07:10 AM
Well I tried my old plugs and wires and ity was still doing it which points me to the distributor.
Old July 29th, 2013, 10:44 AM
Was it doing it before you changed them the first time? Did you change anything else?
Old July 29th, 2013, 11:28 AM
No it wasn't doing it before. They only other thing changed was the 2 front jets in my carb. I went from a 75 to 78 there.
Old July 29th, 2013, 01:33 PM
Try going back to what you had in there before.
Old July 29th, 2013, 02:20 PM
Ill try and see what happens
Old July 29th, 2013, 02:55 PM
brown7373's Avatar
That's a pretty big jump in jet size unless you also installed bigger rods. It would make the mixture a lot richer at cruise and might cause the bog. The normal proceedure is to go to a bigger jet and a bigger rod. Virtually all primary rods have the same size tip, which means a bigger jet would make it richer at full throttle. But if you don't go to bigger rods, the mixture would also be much richer at cruise and part throttle, which is not usually a good thing. A richer mixture only helps if the engine needs a richer mixture. Too rich and you lose power and drivability.
brown7373 is offline
Old July 29th, 2013, 04:56 PM
Its not to rich it still is a little bit lean.
js_specials
August 18th, 2006 10:31 AM
starchildace
March 13th, 2006 02:47 PM
dynamic88builder
November 25th, 2005 08:31 PM
Gee
January 27th, 2005 04:57 AM
Gee
Cars Wanted
January 26th, 2005 12:02 PM
Quick Reply: skipping problem
