330 Stroker (402ci)
Old May 3, 2026 | 05:42 AM
cutlassefi's Avatar
330 Stroker (402ci)
Just finished an EFI’d 330(1a block) Stroker build.
My 4.00” stroker crank
6.125 I beam rods
4.00” Racetec piston, 15cc dish, 9.75:1 comp
Out of the box new Edelbrock SB heads
Small hyd roller
Port matched RPM intake
Edelbrock TB
Holley Terminator Sequential EFI
Going in a ‘64 Vista Cruiser
462hp/491tq
Still modifying the brackets for the coils, but it runs REALLY well. This crank will transform a 330 the same way it does a 350!
Old May 3, 2026 | 07:30 AM
Mr Nick's Avatar
Very nice! Who did the MPFI conversion on the intake? Any more pics?
I don't see a crank trigger, is it running a modified distributor?
MPFI is on my realistic future to-do list, CNP DIS is in the "wish list" column.
Old May 3, 2026 | 07:41 AM
cutlassefi's Avatar
Wilson did the bungs. I used a Holley Dual sync Dist. They actually work pretty well. Then just std LS coils. I’ve done a few this way, all had good results.
Old May 3, 2026 | 07:57 AM
65B01Delta's Avatar
Very Nice.
Old May 3, 2026 | 08:24 AM
Sugar Bear's Avatar
Amazing numbers, nice work!
What is the CID now?
A video of it running would be great if you have the time.
Old May 3, 2026 | 11:22 AM
VC455's Avatar
Barely Registered
Title in his post states: 330 Stroker (402ci)
Old May 3, 2026 | 12:05 PM
Sugar Bear's Avatar
Yes it does, my mistake thanks!
Old May 3, 2026 | 02:56 PM
cutlassefi's Avatar
Plus you can do the math
Bore x Bore x Stroke x .7854 x # of cyls.
Old May 3, 2026 | 04:45 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Very nice, what are the cam specs? Ball park is fine. Yeah, the Dual Sync was easy to set up.
Old May 3, 2026 | 05:44 PM
cutlassefi's Avatar
In the low 220’s @.050.
Old May 3, 2026 | 06:43 PM
Single pattern?
Old May 3, 2026 | 09:32 PM
cutlassefi's Avatar
Single pattern?
Nope, but that’s the intake duration.
Old May 4, 2026 | 02:30 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Very nice numbers, that VC sure is going to move
Jason Schleef
Mar 3, 2024 11:09 AM
Kirdid
May 22, 2023 06:55 PM
65Gutless
Nov 22, 2018 06:45 AM
The Stickman
Jul 13, 2014 07:05 AM
jag1886
Oct 16, 2010 05:04 PM
