Brainbeau 66’ questions
Old Dec 27, 2025 | 04:13 PM
Noodles66442's Avatar
I saw a video of the restored car. It sounds amazing. Does anyone no what they did to the engine? Who built it?
Old Dec 27, 2025 | 06:34 PM
66-3X2 442's Avatar
The thing that probably gives you the sound you like is the Tubular Automotive headers the car has on it. Looks like a bowl of spaghetti underneath the car.
Old Dec 27, 2025 | 09:10 PM
OLDSter Ralph's Avatar
I suspect the engines were built "in house" with machining done by an outside shop. Meticulous assembly and adherance to NHRA registered (Oldsmobile) blueprint specs. In 1968 Berejik had a "Performance Center" near the dealership.
Here is the headers on a 1968. They were JR headers fabricated in Michigan.
Old Dec 28, 2025 | 07:11 AM
Jpl67's Avatar
Like these.
Old Dec 28, 2025 | 08:10 AM
Originally Posted by Jpl67
Like these.
Nope, those are something different. Yours cross over from side to side. The ones on the Berejik car circle around and join the collector on the same side. They also are 2" tubes. I have a set on my '70 W-30 that came off my '68 H/O (W-45). Next spring I'll get my W-30 out and take some good pics.
Old Dec 28, 2025 | 08:17 AM
fleming442's Avatar
So, the Tubulars are equal length? The crossover pipes are a 180⁰ design that is supposed to help with scavenging. I tried making a set, once, never finished.
Hairy Olds's Avatar
Shoveling Snow
Old Dec 28, 2025 | 04:37 PM
CANADIANOLDS's Avatar
they’re not equal length. the rear two back pipes on each side are very short compared to the others, which are also not equal.
Old Dec 28, 2025 | 04:43 PM
The 66 car has the 180 style originally which were 1 3/4” , the 67 car didn’t, it had the bigger 1 7/8” or 2” where the two front cylinders on each side wrapped around the front of the cross member then straight into the collector on the same side . I have pics of both cars from years ago
Old Dec 29, 2025 | 04:29 AM
https://www.facebook.com/HotRodHarry...9980779965435/
This is the video I hope the link works. Just sounds wayyy to good for a 66 w-30 cam. I no the headers change it but….
Old Dec 29, 2025 | 06:04 AM
fleming442's Avatar
Sounds like open headers to me. Put 3 sets next to each other, uncorked, on the same engine, and I dare you to tell me which is which.
You're hearing the cam and compression.
Old Dec 29, 2025 | 06:51 AM
I get that, when we had the old motor in ours it had a w30 cam and it was a very mild sounded motor.
Andy
Jul 21, 2024 07:22 AM
Oldsmaniac
Jun 19, 2019 04:46 PM
jfb
Jun 23, 2017 05:57 AM
TripDeuces
Aug 18, 2011 05:51 AM
