New headed 350
Old Dec 9, 2025 | 02:21 PM
cutlassefi's Avatar
New headed 350
Here’s what you can expect when doing a 350 when the new heads are released. The rest is as follows;
Edelbrock VRS 750 carb
RPM Intake port match by Peyton Hunt
Comp 1632-16 rockers
Comp 85701-16 roller lifters
Custom Comp Hyd Roller, 233/238@.050, 108 lsa
FAST XDI Ready to Run Dist
New Mahle SBO 4.125 bore piston kit
Molnar 6.00” H beam rods
N crank
1 3/4 dyno headers and 2.500” exhaust
93 pump gas
1.00” open spacer
Torquey little bastard!
Old Dec 9, 2025 | 04:46 PM
fleming442's Avatar
Nice!
Old Dec 10, 2025 | 05:02 AM
JohnnyBs68S's Avatar
So 362 ci? What did the CR end up being?
Nice numbers. Almost too nice......... teasing me to question my decision to go stroker, LOL.
Old Dec 10, 2025 | 06:28 AM
HighwayStar 442's Avatar
Nice! But wait for the ALL CAPS KARENS. You know its coming Good job Mark!
Old Dec 10, 2025 | 08:27 AM
Sugar Bear's Avatar
Very impressive, nice work! Those torque numbers are excellent.
Old Dec 10, 2025 | 09:46 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
I didnt do anything to the speedmaster heads except have them milled down to 64 CC on my 358 build and they made a tad more tq then these new heads, you did make a little more HP then I did, but then again I didnt have my progression HEI on the dyno either. I dont see the point of spending way more for no gain, at least the new heads have a scallop and you dont need to run an elec fuel pump so I guess you make up some saving on that end.
Old Dec 10, 2025 | 11:09 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Nice build. Dave, you were down about 30 HP and up over 10 ft-lbs of torque? I wonder if the slight torque loss is port size, larger port intake and as cast head port or just the at 10 degree larger cam?
Old Dec 10, 2025 | 12:16 PM
skyhigh's Avatar
Mark didnt mill the heads either, so there might not have been around the same compression. Either way its a nice build with out of the box heads. I thought dale said something about port match, to much for a 350?
Old Dec 10, 2025 | 12:28 PM
If it is zero deck and a .040" head gaskets, it should be right around 10.25 to 1. The bigger bore and a 7.2cc smaller dish bumps it around to 1 higher vs his last mule. Either way over 400 ft-lbs from the start of pull with well over 450 HP is no slouch. Nick's is struggling to get his dyno read at 2500 rpm for some straight 6 builds.
Old Dec 20, 2025 | 08:41 AM
cutlassefi's Avatar
Final with air cleaner etc.
Old Dec 20, 2025 | 03:44 PM
VORTECPRO's Avatar
Looks good to me!
Wyocutlass71
Sep 17, 2025 03:19 PM
cutlassefi
Oct 20, 2024 03:04 PM
cutlassefi
Aug 10, 2024 07:38 PM
815Cutlass1972
Jul 16, 2016 01:56 PM
coppercutlass
Jul 8, 2013 07:56 PM
