1983 royale delta 88 63,000 miles
Hi
First time posting i recently purchased a olds 1983 88, I'm undecided if i should replace the whole engine in the car to make it new and upgraded.
Anyone have thoughts on it, if i should keep the engine under the hood all original
what kind of engine and size could i put in the frame ?have a engine motor in mind ?
I am in NYC any high performance engine builders out here for a recommendation.
As said the 403 is an easy and direct swap. Early 330 or 350 heads boost compression up from the factory high 7's to around 9 to 1 with stock pistons. Are you planning on running the factory CCC setup?
Any good recommendation for a 500-600 hp engine that fits the frame ?
https://www.reddit.com/r/Oldsmobile/...t=share_button
Here is the video of the car
