1983 royale delta 88 63,000 miles
Old Sep 25, 2024 | 04:17 PM
Jedi33nyc's Avatar
Hi
First time posting i recently purchased a olds 1983 88, I'm undecided if i should replace the whole engine in the car to make it new and upgraded.
Anyone have thoughts on it, if i should keep the engine under the hood all original
what kind of engine and size could i put in the frame ?have a engine motor in mind ?
I am in NYC any high performance engine builders out here for a recommendation.
Old Sep 25, 2024 | 04:54 PM
75 W-30 H/O's Avatar
Sounds real....
Old Sep 25, 2024 | 07:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I would put a warmed over 403 in it.
Old Sep 26, 2024 | 04:17 AM
^^^THIS^^^
A 403 is the same externally as the 307 that came in your car.
Old Sep 26, 2024 | 05:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As said the 403 is an easy and direct swap. Early 330 or 350 heads boost compression up from the factory high 7's to around 9 to 1 with stock pistons. Are you planning on running the factory CCC setup?
Old Sep 26, 2024 | 05:27 PM
Jedi33nyc's Avatar
Any good recommendation for a 500-600 hp engine that fits the frame ?
https://www.reddit.com/r/Oldsmobile/...t=share_button
Here is the video of the car
Old Sep 26, 2024 | 06:25 PM
Looks like a good honest mostly original car. If the engine is tired, I'd concur with the others -- you could build a nice 403. Other than that and paint and some interior work, I'd say DFIU.
Old Sep 26, 2024 | 10:21 PM
For 500+ HP either a 455 or a 350 with Cutlassefi stroker 350 4" crank. Neither will be cheap, especially at the 600 HP mark.
Old Sep 27, 2024 | 09:18 AM
Jedi33nyc's Avatar
Ok Ill speak to my mechanic and will ask around
Thanks you all for your kind expertise.
Old Sep 27, 2024 | 09:19 AM
Jedi33nyc's Avatar
Dfiu = dont *** it up ?haha
Old Sep 27, 2024 | 03:38 PM
Is BTR still in business?
Old Sep 28, 2024 | 05:55 AM
Pretty sure he is and would be perfect for the power he wants.
Old Sep 28, 2024 | 06:34 AM
Kinda what I was thinking and he's in NY.
Old Sep 28, 2024 | 10:24 PM
Jedi33nyc's Avatar
Dang you guys are a bad influence.
Thanks again ill do some research boyz
NiceOld(s)Car
Jun 6, 2024 04:21 AM
maitrepathelin
Nov 29, 2022 08:31 PM
jenyanke
Jan 24, 2015 04:21 PM
Rodr
Oct 8, 2006 08:54 AM
Yuneek
Aug 5, 2006 01:20 AM
