496 Build
Old Aug 1, 2023 | 09:40 AM
cutlassefi's Avatar
496 Build
This is a true 496(4.190x4.500).
New Edelbrocks
Eagle Stroker crank
Scat Rods
Racetec pistons
10.5:1
Comp hyd roller, 244/250@.050
Topline hyd roller lifters
My HS 1.65 rockers
Edelbrock RPM intake
1/2” spacer
Brawler 950 carb
Old Aug 1, 2023 | 01:42 PM
70W-32's Avatar
Looks good.
Old Aug 2, 2023 | 06:47 AM
anoldsman's Avatar
Nice!!!!
Old Aug 3, 2023 | 09:31 AM
BillK's Avatar
It would be nice to see what it did at lower rpm, especially the torque.
Old Aug 3, 2023 | 02:45 PM
cutlassefi's Avatar
I can pull it down to 2000rpm if I want to, my dyno will hold it. But that's REAL hard on parts. Really no need other than to see a number on a piece of paper.
Old Aug 3, 2023 | 06:01 PM
OLDSter Ralph's Avatar
Whats real hard on parts ? Dyno parts ? Engine parts ?
From 1,000 to 3.500 RPM's is where most engines operate a huge percentage of the time. Its also the RPM range that most "Stop light Gran Prix's" use.
The numbers on a piece of paper are what gets the car moving. More torque, more acceleration.
Old Aug 3, 2023 | 06:06 PM
cutlassefi's Avatar
Engine. Dyno will hold it. But that’s the issue. To hold the engine at say 2000rpm or so before you release it is tough. But on something like this, you just know it’s going to fry any rubber that’s on it at just about any rpm.
Old Aug 3, 2023 | 09:14 PM
66SportCoupe's Avatar
Absolutely correct sir!
Old Aug 11, 2023 | 11:34 AM
GEARMAN69's Avatar
Sweet !
Old Jan 18, 2024 | 08:50 AM
mrrjay243289's Avatar
Olds 496 stroker
New Edelbrocks
Eagle Stroker crank
Scat Rods
Racetec pistons
10.5:1
My HS 1.65 rockers
1/2” spacer
Brawler 950 carb
I'm liking the power & torque output specs of this build, but would this setup work with power brakes & AC?
Old Jan 18, 2024 | 12:00 PM
cutlassefi's Avatar
Yes, but more so with just a bit less cam.
Old Oct 20, 2024 | 05:43 AM
rocketboy's Avatar
How do you think a torker intake would have affected the power? Do you think it would’ve helped?
Old Oct 20, 2024 | 06:23 AM
cutlassefi's Avatar
No. I’ve dyno’d a half a dozen combinations with that intake on them, some were mine, some were from others. None of them ever made more than 525 with that intake.
Old Oct 20, 2024 | 06:35 AM
rocketboy's Avatar
ok that’s good to know. I’m saving up parts for a 495 stroker.
did you cut down the center divider or just add a spacer on the intake?
Old Oct 20, 2024 | 03:04 PM
cutlassefi's Avatar
Cut the divider. But you may want to add an open spacer as well, as much as your hood clearance will allow.
fleming442
Jul 12, 2021 11:38 AM
cutlassefi
Apr 25, 2021 10:50 AM
69Chrgr
Apr 24, 2021 07:50 AM
815Cutlass1972
Jul 16, 2016 01:56 PM
jims2000lt
Jul 9, 2013 07:36 PM
