Main spacing from block to block?
Old December 9th, 2020, 06:41 AM
Bernhard's Avatar
How accurate are the Oldsmobile BBO & SBO main bearing saddles spaced from block to block? The question is directed toward bottom end supports and how much tolerance is built into them to allow for casting tolerance. Blocks can suffer from core shift in cylinders and the cam tunnel. Are the mains also vulnerable to core shift?
Bernhard
Bernhard is offline
Old December 9th, 2020, 04:46 PM
cutlassefi's Avatar
Bernhard
I’ve witnessed bolt misalignment but not really any difference in distance one saddle to the next.
cutlassefi is online now
Alf Lehtinen
August 13th, 2020 04:12 PM
July 9th, 2019 09:27 AM
olds_freak
November 30th, 2016 04:32 PM
Octania
April 7th, 2016 02:51 PM
olds_freak
April 29th, 2015 08:23 PM
Quick Reply: Main spacing from block to block?
