wild 70
Old Aug 25, 2013 | 06:40 AM
wild70's Avatar
Talking wild 70
Im knew and would like to get an idea of what I can expect this car to do at the track. 350-40 over , flat top 10.5/1 speed pro pistons, forged crank, not sure about rods, cam is crane hydraulic special PT804551X-HIT282-2, 491 intake-518 exhaust, Advertised Dura 282- 290, roller rockers, #5 heads/2in intake-170 exhaust, ports and bowls worked over erg ground out, ceilings on intake raised 1/8in, all gasket matched, holly street dominator intake,2 in spacer, 650 single pump holly ,pertronics distributor HEI/taylor 10mm wires , msd 6AL, 1 7/8 headers into 2 1/2 in pipes/ flowmaster 40 mufflers. 350TH/3500 stall,433 gears 12 bolt, M series M/T on the back hope for slicks when I go, stock suspension. Any opinions appreciated. Have another great day.
gil
Old Aug 25, 2013 | 07:59 AM
drjr56's Avatar
I had a 400g motor in a 69 442.With a stage 2 built Qj, performer manifold,using the same Cam you are.Stock heads with the bowls cleaned up and a 3 angle valve job,373 gears.The car went 100 mph in the 1/4 mile. I think that your 350 should do that at least.My ET was high 13's.I ran the car though the exhaust. Did have hedman headers and 2 chamber flowmasters,but I never opened the headers.
Old Aug 25, 2013 | 09:56 AM
wild70's Avatar
wild70
ya I ran a 72S with minor work 750 DP holly, W31 cam, edelbrock duel plane intake, 8.5/1 comp, headers, and 433 gears back in early 70s must have been the combo, went 13.00 @ 100mph open.checking with you guys as this thing is violent in comparison,lol.
thx
gil
Old Aug 25, 2013 | 11:51 AM
oldsmobiledave's Avatar
Originally Posted by wild70
Im knew and would like to get an idea of what I can expect this car to do at the track. 350-40 over , flat top 10.5/1 speed pro pistons, forged crank, not sure about rods, cam is crane hydraulic special PT804551X-HIT282-2, 419 intake-518 exhaust, Advertised Dura 282- 290, roller rockers, #5 heads/2in intake-170 exhaust, ports and bowls worked over erg ground out, ceilings on intake raised 1/8in, all gasket matched, holly street dominator intake,2 in spacer, 650 single pump holly ,pertronics distributor HEI/taylor 10mm wires. 1 7/8 headers into 2 1/2 in pipes/ flowmaster 40 mufflers. 350TH/3500 stall,433 gears 12 bolt, M series M/T on the back hope for slicks when I go, stock suspension. Any opinions appreciated. Have another great day.
gil
Are you sure that your cam specs are typed in correctly? 419 / 518 ????
There are no forged 350 cranks. I gather you are using a 330 crank then? Yes? No?. Maybe?
Why such a tall spacer?
Not enough carb. Factory 350 used a 750. Why goes less carb now?
Stock suspensions is not the best. Why not make simple mods to improve your 60' times?
Old Aug 25, 2013 | 12:21 PM
svnt442's Avatar
Kind of...
A Q-Jet will only flow what is demanded of it. The rear top flapper doors regulate the amount of air based on demand. Yes the secondary throttle plates open wide on full throttle, but the secondaries will only open as far as the air flowing through them will "push/suck" them open.
Old Aug 25, 2013 | 01:13 PM
wild70's Avatar
Wild70
Sorry 491-518, 1.6 rocker arm ratio, max RPM 5500-6500 float. Must be cast crank then lost some of info when car purchased in 2007never seen bottom end, was told by numerous people spacer would provide better mid range, time, will tell when I get to track can always reduce or remove right. As for suspension, money was part of issue and not a full time strip car- street toy. carburation on this car is not an issue goes like hell no spit or sputter good burn at plugs yes could spend a ton more but why, have done some homework, varied opinions and this is what I seek.
thx
gil
Old Aug 25, 2013 | 01:19 PM
drjr56's Avatar
Looks like that Cam mentioned should be 491/518 if it's the crane HIT 282-2 I used in the 400G.
Old Aug 25, 2013 | 01:24 PM
wild70's Avatar
Wild70
Old Aug 25, 2013 | 01:27 PM
wild70's Avatar
Wild70
thx one of the other members caught my typo, never could land secretarial job, cant type fast or spell.
gil
Old Aug 25, 2013 | 01:34 PM
coppercutlass's Avatar
Chevy budget Olds powered
I ran 13.3's with a 350 and a 600 cfm carb. The 650 dp is what I got now and it felt better on the butt dyno on the old combo. I do have a 750 3310 im curious to see how the 650 does vs the 750 both will be box stock.
Old Aug 25, 2013 | 03:34 PM
drjr56's Avatar
You and me both my man....good thing there's alot of good eye's here...
jrzybob442
Sep 28, 2010 08:25 AM
dc2x4drvr
Sep 22, 2010 12:08 PM
wmachine
Jun 8, 2010 05:47 PM
BLESSEDBYGOD
Mar 12, 2010 11:42 AM
Jamesbo
Aug 12, 2009 11:48 AM
