The W43 at the Autorama
Old Mar 1, 2024 | 08:05 AM
Bernhard's Avatar
https://www.hagerty.com/media/news/h...bTu2znKLyDBx5s
Old Mar 1, 2024 | 08:24 AM
tru-blue 442's Avatar
Old School Olds
Thanks for the post. Good to see they put it on the road!
Old Mar 1, 2024 | 09:57 AM
70W-32's Avatar
Hopefully GM doesnt repossess this engine like they did the one that was displayed at the REO Museum
Old Mar 1, 2024 | 11:47 AM
Bernhard's Avatar
Dyno results from the W43
This is from a Facebook post
So, what kind of power does this 32-valve V-8 produce? “We were prudent during testing to avoid blowing up our irreplaceable parts. Imposing a modest redline, we measured 560 hp at 6000 rpm and 540 lb-ft of torque at 3600 rpm,” James Kryta notes. “But eliminating the significant restrictions by adding multiple carbs and efficient exhaust headers would easily have improved those figures.”
Old Mar 1, 2024 | 12:37 PM
dc2x4drvr's Avatar
Thanks….just gorgeous!
Old Mar 1, 2024 | 02:08 PM
Texas442's Avatar
1971 442 conv
And here is the video of the Team
Old Mar 1, 2024 | 02:39 PM
Old School Olds
Cool video Al. Did you get to hear it run? Absolutely beautiful ride, a truly 1 of 1.
Old Mar 1, 2024 | 06:59 PM
And of course they had to put an "X" on the valve cover...
Old Mar 2, 2024 | 06:34 AM
I never saw that on a valve cover until they started doing it.
Old Mar 2, 2024 | 06:35 AM
Kinda my point
Old Mar 2, 2024 | 08:26 AM
jensenracing77's Avatar
I made a facebook post that it was the greatest engine but that X is triggering my OCD. I have been around these cars and the only place I have found the "hand drawn" X is 72 W-30 engines. Later it was proven that there was an X on "I think" 74 HO 455 engines.
Old Mar 2, 2024 | 10:03 AM
72Ucode supreme's Avatar
One of a kind..
Seen this Olds yesterday at the show beautiful ride. I wish this would have made it to production to take on hemis..
Old Mar 2, 2024 | 01:44 PM
442Fred's Avatar
Kinda my point
Seriously this a big deal an "X" on the valve cover? He managed make the parts he was missing to build it, then to get it running and put it in a car we should be celebrating the fact that someone was willing to go to this extreme. Who cares about an "X" when he brought this engine to life.
Old Mar 2, 2024 | 02:15 PM
Fred, no one is criticizing the workmanship or the effort involved in pulling this off. Clearly it's an amazing piece of work. The "X" on the valve cover has been a joke for years.
Old Mar 2, 2024 | 02:59 PM
Rocketguy's Avatar
The quality of the car and putting together the of engine is something that only enormous resources and cash could pull off. Well done Kryta (sic?) brothers and the craftsman whom constructed it. I loved the W-43 emblems.
I never knew the W-43 was a four valve per cylinder. It's really interesting to see how the engineering team pulled it off. From the pictures it looks like they ran two valves per one pushrod with a very unique adjustable rocker arm set up. I still don't understand how the timing the valve train works.
Old Mar 2, 2024 | 03:11 PM
The shaft-mounted rocker arms were forked. One pushrod opened both valves. This was the fundamental problem that caused Olds to cast unique blocks with a raised cam carrier to improve pushrod angle. Valve timing is no different than in any other pushrod motor. One cam has intake and exhaust lobes on it. Both intake valves open and close together, as to both exhaust valves. Other than the much higher contact loads, that's no different than for a two-valve motor. Like a Chrysler Hemi, the intake pushrods run at a slightly different angle from the exhaust and the rockers are "backwards".
Old Mar 2, 2024 | 05:15 PM
Question, With the cam being higher in the block, Would it need the left and right bank lobes farther apart than a standard 455 cam?
Old Mar 2, 2024 | 05:20 PM
Eric, it depends on the angle of the lifters, but as you can imagine, raising the cam would also change the angle the lifters needed to be at to be inline with the cups on the rocker arms. You can get a sense of the lifter bank angle from this photo. I should add that the reason the lifter galleries had to be bolt-in was that the angle of the lifter bore was "below" 45 deg, so there was no way to machine the bores if they were integral to the block.
Old Mar 2, 2024 | 05:45 PM
That makes since to be actually. Had to read it twice though.
Old Mar 2, 2024 | 07:10 PM
The other thing to keep in mind is that since the valve stems are at the top and bottom of the head, the pushrods actually have to come up between the rocker shafts, which makes them "flatter" in the block than on a two-valve engine where the pushrod holes are at the top side of the head. Think of the pushrods in a Chrysler hemi.
Old Mar 2, 2024 | 08:18 PM
Bernhard's Avatar
This is posted on Facebook
Author
This from the Hagerty article about the car the engine and the Kryta twin brothers
The plot thickens. “In the early 1970s,” John says, “shortly after the W-43 lost all hope of entering production, several Olds engineers and PR personnel flew out to California to tout their project for Petersen Publishing Company editors at Car Craft, Hot Rod, and Motor Trend magazines. At that time, this wasn’t a complete running engine but rather a hollow shell suitable for photography and a collection of internal parts highlighting the W-43’s attributes.” (Read our technical breakdown of the Oldsmobile W-43 V-8 here.)
“The trip to California was to gain publicity, after the engineering project had been terminated by GM’s upper management. Given that, the Olds folks asked the writers to chuck these engine parts in a dumpster after their stories were completed. Lucky for us, that request was ignored. These priceless W-43 components went home with someone from Petersen in 1971, only to resurface decades later.
Oldsmobile V-8 OHC_W-43 valves
GM
Oldsmobile V-8 OHC_W-43 bores
GM
GM Archives Oldsmobile V-8 OHC
GM
“Cajoling the vintage parts into a running engine was no small feat. The first problem was a parts shortage. One cylinder head was missing, so we had to reverse engineer it and a few other components. Extensive machining was required. All told, 20 people got involved, including one ex-Oldsmobile engineer who requested anonymity. Scott Tiemann, the CEO of Supercar Specialties in Portland, Michigan, quite capably handled final assembly.”
Autorama Oldsmobile 4-4-2 valve cover detail
Chris Stark
Old Mar 3, 2024 | 04:11 AM
They read the forums, I am sure they are fully aware of us poking fun at the X issue. I suspect it is motivation for them to keep doing it, lol. At least that is what I would do.
Old Mar 3, 2024 | 05:41 AM
Just made my day. They have a really small mention of the W41 engine in this one.
https://www.inlinetube.com/blogs/inl...ocWgY8x_sCDHNI
Old Mar 3, 2024 | 06:25 AM
75 W-30 H/O's Avatar
Too bad it's not going to Rosemont next week. I'd like to see it in person.
Old Mar 3, 2024 | 09:01 AM
Old School Olds
I would like to HEAR it.
Old Mar 3, 2024 | 09:25 AM
That too.
Old Mar 3, 2024 | 09:43 AM
wr1970's Avatar
Okay excuse me why everyone was poking fun of the X on the covers! So what is the joke? I am always a day late and a dollar short. Sometimes absolutely clueless 😂😂
Old Mar 3, 2024 | 10:11 AM
Go read post #11
Old Mar 3, 2024 | 10:16 AM
There is some truth to that. They also led to the Quad8, that had lineage to the Northstar.
Old Mar 3, 2024 | 12:02 PM
OLDSter Ralph's Avatar
My 1970 W-30 had the hand applied "X" made by a yellow paint stick on the center of the drivers side valve cover. It was about 2 1/2" tall and 5-6" wide.
  #31
If I had unlimited resources I would love to see this one running.
Old Mar 3, 2024 | 12:50 PM
  #32
66SportCoupe's Avatar
There are 2 complete quad8 engines complete and in the hands of retired Oldsmobile engineers. They will sell them.
Old Mar 3, 2024 | 01:51 PM
  #33
I assume others have noticed but they had to get creative with the steering shaft. You can see the U joint at the column.
Old Mar 5, 2024 | 02:34 PM
  #34
OLE442's Avatar
Be sure to post a video of it running if it's ever released. Until then, parts is parts! JMO!
Old Mar 5, 2024 | 05:01 PM
  #35
body 51's Avatar
from the advertisement
Old Mar 6, 2024 | 02:24 AM
  #36
1970cs's Avatar
Lansing built
I reposting a picture of the Pikes peak Toronado from Oldsmobiles experimental engineering. If you look at the valve cover and spark plug locations. This looks a lot like it. But this is supposed to be a 425.
Pat
Old Mar 6, 2024 | 08:56 AM
  #37
Pat
I recall seeing a disclaimer saying "Specially prepared" in the advertisements. That was a "clue" to me they didn't just drive it off a showroom floor. Looking at the valve covers doesn't tell me what displacement the engine has. What clue are you seeing ?
Old Mar 7, 2024 | 06:18 PM
  #38
DR_DAN's Avatar
Pat
this is approximately 1 of supposed 3 first design engines built. All the others ( 4 I believe) had the raised cam tunnels Joe spoke of earlier in this thread. Where are the rest? Who knows
sammieolds
Dec 29, 2015 10:57 AM
tailfins
Dec 5, 2014 05:19 PM
HurstLightning84
Nov 30, 2013 07:27 PM
NightStalker
Feb 19, 2012 11:21 PM
