Is there a supercharger for the 350 V8?
Old Jun 28, 2013 | 02:02 PM
JamesRustle's Avatar
Title. It's a 72 cutlass s.
Old Jun 28, 2013 | 02:53 PM
Yes, Procharger, B&M, Supercharger USA for blowers, ....
Old Jun 28, 2013 | 05:00 PM
Octania's Avatar
http://www.ebay.com/bhp/electric-supercharger
"this spins, this spins, they are exactly the same"
while looking at a real turbo fan and a stamped POS electric fan.
oh-strie-leean Red Greens add TWIN leaf blowers to the 32 HP daihatsu after the epay electric stuporcharger gained about -10% power. Technically, negative gains are as advertised- because "up to" 50 HP gain guarantees only that your gains will not EXCEED that level, and if they did, who would complain?
Old Jun 28, 2013 | 08:44 PM
I like the twin leaf blowers. Professionally sealed with duct tape.
Old Jun 29, 2013 | 01:13 AM
Links plz
Old Jun 29, 2013 | 03:59 AM
oldsman72's Avatar
Originally Posted by JamesRustle
Links plz
Complete Olds 350 kits:
http://www.superchargerusa.com/olds_...et.htm#350olds
Old Jun 30, 2013 | 12:10 AM
Originally Posted by oldsman72
Thank you very much.
Old Jun 30, 2013 | 07:55 AM
I've never heard of Superchargersusa, however I have seen Olds supercharger setups from BDS, which is a company who's been doing this for decades. Except for the long-out-of-production Sharp blower intake manifolds, no one makes a blower manifold for an Olds motor. Most that I've seen are fabricated from an Offy single plane dual quad intake, with the carb flanges milled flat and a thick aluminum mounting plate bolted or welded in place. I would steer clear of a fabricated manifold that starts with a single 4bbl intake.
Old Jun 30, 2013 | 08:07 AM
captjim's Avatar
Don Hampton makes a kit for an Oldsmobile, too,
http://www.hamptonblowers.com/PRICE.HTML
Scroll down, starts ar $3700
Old Jun 30, 2013 | 05:24 PM
krooser's Avatar
Hot Rod Has Been
I don't see any problems using a manifold fab'd from a single or dual four intake as long as the part is well made and the seller (if a new part) stands behind their product.
Making stuff work for an obsolete or odd ball engine is what hot rodding is all about. Early Caddy's can use Studebaker adjustable rocker arms... there are hundreds of these modifications around that allow one family of engines to use another's parts... just putting a GMC 6-71 blower on any engine is another example.
Old Jun 30, 2013 | 06:14 PM
The main thing with supercharging is a the engine needs to be built for the amount of boost that you are going to be running.
Old Jul 1, 2013 | 07:58 AM
There's no problem with the fabricated intake and frankly that's the only way to mount a GMC-style blower on an Olds motor. My point of avoiding the single 4bbl version was simply due to the restriction that the small hole imposes. Kinda makes no sense to install a supercharger then squeeze it all through a single 4bbl opening.
Old Jul 1, 2013 | 09:22 AM
Octania's Avatar
Huh.
the epay ads for the electric unit don't caution about that. I wonder why?
So, "up to" how much power does the BDS or similar blower add?
They could advertise them as good for "up to" 1500 extra HP, right?
Old Jul 1, 2013 | 10:13 AM
Originally Posted by Octania
Huh.
You would think their Attorneys would have suggested some sort of disclaimer. Just wait until the leaf blower guys find out about the new application for their products.
I think the rule of thumb is 34% for 5#'s of boost.
Compression ratios and fuel quality play a big part with superchargers. You can get tremendous gains from them.
Old Jul 1, 2013 | 03:15 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Dyer's has Olds small block kits, too.
http://www.dyersblowers.com/
Old Jul 1, 2013 | 04:48 PM
captjim's Avatar
Never mind horsepower, IMO the main benefit of a blower on a street car is the ridiculous off-idle torque. In most cases, you need less gear and are done by 5500.
FIRST 442
Nov 11, 2018 06:18 AM
Wildcard
Jan 20, 2013 12:06 PM
OldsCutlass
Jun 11, 2011 03:26 PM
84oldsDelta88
Apr 18, 2009 10:30 PM
RichardWilliams
Apr 10, 2009 05:34 AM
