transmission question
Old June 21st, 2013, 05:04 PM
Chevy budget Olds powered
coppercutlass's Avatar
So im tracing down some noises and im replacing my flex plate . I just got done putting the trans in. Not done yet just 2 bolts and the crossmember. My question is the is a 1/4 in. gap between the converter and the flex plate it seem to be excessive im used to just moving the converters back a smidge. Im thinking the converter just may be the noise im trying to zero in on . What do you guys think ?
Ps. disregard the blue goop off the pan I use a thin film on silicone on my pan and I removed it to inspect it and just installed for the trans install so the loose ends are just hangin. I got a new seal lol.
coppercutlass is offline
Old June 22nd, 2013, 06:55 AM
The torque converter should just slide forward. Rotating it a bit may help.
oldcutlass is offline
Old June 22nd, 2013, 07:07 AM
I know that .,I'm just asking if the gap is correct or excessive. I'm used to it just sliding a bit . This seems kinda like a lot. I ran this converter before and it just seems like that's kind of big gap to close up. I'm being overly cautious because I'm traking down noises . I already spun it back and it mates good but I guess this time around I'm watching every little thing.
Old June 22nd, 2013, 07:20 AM
380 Racer's Avatar
The more expensive converters I have had, used a thick washer/spacer between it and the flexplate if needed.
380 Racer is offline
Old June 22nd, 2013, 07:24 AM
I understand, better safe than sorry.
Old June 22nd, 2013, 07:34 AM
380 I think that's what I need. This was a custom built unit from a shop on ebay. had good reviews. Is there a certain width gap that there should be before bolting the converter when you ran your washer ? IM thinking the noise I was hearing is my converter .
Old June 22nd, 2013, 08:03 AM
Depending on who's train of thought, I always thought it was up to .250 no spacer required for a T400 because it has 1.187 worth of travel.
Old June 22nd, 2013, 08:29 AM
so I can get some .125 washers and i will be in the right area I need to be . Im going to measure it right . I used a 1/4 inch socket extension and it fit in. I was beat after a 12hr day yesterday and just put the trans in place and got the grunt work done. I should be leaving work in a few hours and i'll be back at it .
Old June 22nd, 2013, 08:40 AM
brownbomber77's Avatar
I remember I had the same problem on a 400 I had a few years ago. I just put a couple grade 8 washers between the flexplate and converter and didn't have any issues.
brownbomber77 is offline
Old June 23rd, 2013, 05:23 AM
Thanks for the input you guys I appreciate it .
Old June 28th, 2013, 06:27 PM
Well guys I shimmed the converter .185 But I think I found thr culprit of my noise at high rpm. drive shaft hitting my safety loop. I guess I need a torque strap.
Old June 29th, 2013, 12:04 PM
64Rocket's Avatar
With that gap you show, is that with the converter seated against the crank ??
Maybe that converter was made for a mid motor plate.
If it was seated and still have a gap, that must be for a motor plate.
Now if you did not seat it and run the spacer, you are depending on the bolts to hold it center, to me is not good. That is what the hub is for.
JMO
Gene
64Rocket is offline
Old June 29th, 2013, 12:45 PM
No that's with it pushed in towards the trans. It just seemed like a big gap to cross.
Old June 29th, 2013, 03:01 PM
Ok guys. here is the scoop. I put in anew flexplate new front tires and the car runs much better. I held second gear up to about 4k. No noises then I put it in 3rd and immediately started hearing the grinding noises again. Could the converter be the culprit? I thre that possibility but if it was the converter it would do it all the time Is what im thinking correct? I don't think it's my drive shaft. Im gonna take the hoop off and take it for a spin tomorrow. But if it was my drive shaft it would do it in 1st and second as the engine is pulling hard. Any thoughts guys. I know this is more of transmission section topic but since im racing it I figured someone hear has had a trans go bad before.
Old July 2nd, 2013, 02:11 PM
Paul Dodd, 10 sec Old's
Paul dodd's Avatar
HI mate dont think converter cos would make a noise in all gears could be something in the trans ! Now excuse me for jumping in on this but i also have a converter problem in that i got a JW from a friend to replace the BnM I blew to bits on a 10 sec Nitrous run. I noticed the JW had a longer hub that fits into the crank and now fitted the converter only pulls forward the minimum 1/8th before stopping leaving it at least another 1/8th away from the flywheel. So i fitted a washer to each bolt but it did not quite fill the gap and started to flex the flywheel as i tightened it, so i tried 2 washers but that was too much sending converter back into trans and so losing the 1/8th clearance i need. So do i try and get some washers made up to the exact gap or as my friends advise take it all out again and have say 1/4 taken off the hub, HELP!
Paul dodd is offline
Old July 2nd, 2013, 02:15 PM
Get a set of dial calipers and measuer the washers at the hardware store that's what I did.
jensenracing77
Ninety-Eight
February 28th, 2009 09:13 AM
svt412
July 4th, 2008 03:37 PM
whizkid88
July 1st, 2008 07:13 PM
Olds64
December 20th, 2007 05:10 AM
Cuttyon22s
July 10th, 2006 11:24 PM
Quick Reply: transmission question
