spark plug ?
spark plug ?
How do I choose the right spark plug for my new build?
First list is the changes I've made;
4.25 stroke Eagle rotating kit. 11 to 1 SRP flat top pistons. .Balanced
3' X-pipe exhaust.
New Edelbrock replacement valve springs.
Had heads cleaned and checked.
Block was bored to .60 over, half filled with hard blok, honed with plates, 0 decked.
7551 RPM Performer on its way. (backordered)
This list is what is the same.
2" Hooker super comps.
1" Moroso open center carb spacer.
Lunati Hyd Flat tappet cam. I have to look up the specs.
880-890 CFM 4150 Holley.
HEI Dist.
My big change from the old to new is the bump in compression and the straight & square maghine work.
I just need to find a chart or something for the plugs to get me close.
Thanks to all who reply.
3' X-pipe exhaust.
HEI Dist.
