spark plug ?
Old Jan 27, 2014 | 07:41 AM
jims2000lt's Avatar
11.52 @116
spark plug ?
How do I choose the right spark plug for my new build?
First list is the changes I've made;
4.25 stroke Eagle rotating kit. 11 to 1 SRP flat top pistons. .Balanced
3' X-pipe exhaust.
New Edelbrock replacement valve springs.
Had heads cleaned and checked.
Block was bored to .60 over, half filled with hard blok, honed with plates, 0 decked.
7551 RPM Performer on its way. (backordered)
This list is what is the same.
2" Hooker super comps.
1" Moroso open center carb spacer.
Lunati Hyd Flat tappet cam. I have to look up the specs.
880-890 CFM 4150 Holley.
HEI Dist.
My big change from the old to new is the bump in compression and the straight & square maghine work.
I just need to find a chart or something for the plugs to get me close.
Thanks to all who reply.
Old Jan 27, 2014 | 11:20 AM
I'd start with the stock plugs and check them after running them for a while. Gap to .045. Then adjust if necessary.
Old Jan 27, 2014 | 12:31 PM
cutlassefi's Avatar
For a performance application always use the coolest plug you can before it fouls.
Old Jan 27, 2014 | 06:19 PM
Smitty275's Avatar
Engine Builder
Street or strip. Aluminum heads correct?
Old Jan 27, 2014 | 06:59 PM
jims2000lt's Avatar
11.52 @116
Street miles per season is usually under 2000. Hope to make a few Olds events and local test and tunes this year.
Edelbrock aluminum heads. Mildly ported and polished by me a few years ago, nothing crazy.
Old Jan 30, 2014 | 05:34 AM
Smitty275's Avatar
Engine Builder
I would start with an Auto Light AR3911.
Old Jan 30, 2014 | 06:16 AM
jims2000lt's Avatar
11.52 @116
The answer I was hoping for. Thank you sir.
I've always used Auto Lights or AC Delcos.
Old Feb 2, 2014 | 06:38 AM
ds00469's Avatar
I have been using E3 spark plugs. part number ETP-E3-52 on summitracing
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
