Schumann oil pump ?
Old Oct 24, 2022 | 04:42 PM
Gene kerr's Avatar
Schumann oil pump ?
Anyone try one of these oil pumps just curious
Old Oct 24, 2022 | 05:19 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have never heard of them but then there is a lot of stuff I have never heard of. To say they are pricey would be an understatement. Hard to beat a good Melling pump.
Old Oct 25, 2022 | 06:31 AM
oddball's Avatar
Yup, I use one. It's a blue printed melling. Is it worth it? I dunno.
They buy batches and mix/match housings and gears to get the best side clearance. Then they mill the housing to get the best top/bottom clearance. The bottom gets milled flat. They also drill holes in the bottom of each gear tooth - I assume that's a cavitation thing. The one I got several years ago had the green spring with a bolt spacer instead of using the pink spring Melling now supplies. Oh, and they replace the bypass spring retention carter pin with a tiny bolt and two nuts.
The large bypass one has some other modifications to it.
You can also just get a Melling and check clearances yourself, and exchange if you don't like it. It's always a good idea to thoroughly inspect and clean parts anyway.
Old Oct 25, 2022 | 06:36 AM
Gene kerr's Avatar
What is your oil pressure at running temp and what are your clearance if you don't mind
Old Oct 25, 2022 | 08:13 AM
68post's Avatar
It's too bad the "Internal Bypass" version is so expensive, the lesser priced version is plenty expensive enough !
Old Oct 25, 2022 | 10:47 AM
v8al's Avatar
Registered Olds Owner
FYI there's also: Precision Oil Pumps.
Old Oct 26, 2022 | 06:06 AM
oddball's Avatar
Mains around 3, rods around 1.75, I think it has 10w30 in it right now. ~70 psi cold, ~20 psi hot idle
This threw me for a loop. The stock Olds design *IS* an internal bypass. So the more expensive one is where they've modified the bypass in some way to handle more volume.
Fun story: this is now permanently in my brain because I was chasing a low oil pressure problem last year. Finally spun up the oil pump with the distributor out to find that I had an *external* oil bypass. Back when the block was machined, the operator sent the boring bar too low and it cut into the main oil feed galley leaving a pea size hole. At the time I didn't know what was going on so assumed it was splash from the oil pump or something. That was fun to fix.
jensenracing77
Apr 7, 2019 10:39 AM
88hurstolds
Oct 6, 2011 08:26 PM
Lawndog
Aug 11, 2011 02:27 AM
Redog
Oct 8, 2010 02:57 PM
dallasite21
Aug 31, 2010 07:54 AM
