RR block vs girdled 425 weight
Old Jan 31, 2022 | 02:17 PM
chadman's Avatar
Rocket Racing block=254lbs
425 block filled w/Mondello steel girdle=236lbs
I also have a 425 block here with a Jeff Smith girdle which I'm confident is heavier than the Mondello girdled one. It's an assembled short block so I can't weigh it accurately. I did weigh it complete when I pulled it and will weigh the complete RR blocked engine that's replacing it using the same top end and accessories before it goes back in.
Old Jan 31, 2022 | 02:21 PM
oddball's Avatar
What do you think this is, ROP circa 2010???
Old Jan 31, 2022 | 03:23 PM
71 OLDS's Avatar
I had this saved in my notes from a post from one of the Olds sites when the RR block first came out: "the RR block is almost 50 lbs heavier then a standard non-filled, non girdled BBO block". Based on that I assume a standard BBO block is around 200 lbs or in the low 200s. Seems to make sense with your filled/girdled weights or at least be in the ball park. Also I see RR still shows the weight of the block right on their site:
ROCKET RACING & PERFORMANCE BBO BLOCK
DECK HEIGHT: 10.625
BORE: STOCK BBO UP TO 4.400”
MAIN BEARING SIZE: STANDARD BBO
MAIN CAPS: ALL 5 4 BOLTS BILLET STEEL
WEIGHT: APPROX 250 LBS (DEPENDING ON BORE)
LARGEST BORE: 4.400”
BELLHOUSING: ACCEPTS OLDS, CHEVY, BUICK, PONTIAC, AND CADILLAC
CAMSHAFT DIAMETER: STANDARD BBO
CAMSHAFT POSITION: STANDARD BBO
CYL WALL THICKNESS: MIN .200 @ 4.400” BORE
DECK THICKNESS: ADEQUATE FOR ALL APPLICATIONS
TORQUE SPECS: MAIN 110FT/LBS
-Joe
Old Jan 31, 2022 | 04:04 PM
71 OLDS's Avatar
One add to this - just found this that I had saved too: I have personally weighed a bare 455 Olds block using the finest Chinesium bathroom scale that WalMart sells, and it came in right at 200 lbs.
BradDC
Jan 2, 2021 10:47 PM
Delmont 88 PA
Dec 16, 2015 03:37 PM
morepwr
Dec 10, 2014 09:02 AM
davoaz
Aug 25, 2014 05:49 AM
ZASX
Aug 23, 2008 07:22 PM
