Roller rockers stock valve cover
Old Jan 11, 2021 | 01:04 AM
shiftbyear's Avatar
Is there a true roller rocker (not just the tip) arm for a 455 Olds that fits under the stock valve cover with maybe a thicker gasket? Thanks
Old Jan 11, 2021 | 02:05 AM
rickw30's Avatar
Harland Sharp.
S5001 for 7/16 stud.
S50026A for 5/16.
Old Jan 11, 2021 | 05:04 AM
oddball's Avatar
s5016 for the best geometry
I use the Olds script valve covers with 3/8" spacers from Rocket Racing plus their thick rubber gaskets. Fits under stock A/C bracket.
Old Jan 11, 2021 | 11:37 AM
cutlassefi's Avatar
Originally Posted by oddball
s5016 for the best geometry.
^^^^^. Use a shorter stud and poly lock and they should fit under stock tins.
Old Jan 11, 2021 | 01:30 PM
young olds's Avatar
I have scorpion rockers, generic thin rubber gasket and factory valve covers. I think the poly locks touch the oil deflector just barely.
Old Jan 11, 2021 | 01:50 PM
jmos4's Avatar
Hi,
Have 65 covers and had to remove the baffles to get them to clear, and thick gaskets, spacers might be a cleaner option?
Regards,
Jim
Old Jan 11, 2021 | 02:16 PM
oddball's Avatar
good point, forgot to mention that I used the provided studs, but got some 1" polylocks.
Old Jan 11, 2021 | 08:46 PM
Schurkey's Avatar
It's not the rocker that interferes, it's the tall adjusting nut. I cut four holes in the baffle of each valve cover so the adjusting nut pokes through.
Tjohn8573
May 19, 2019 07:34 AM
zeeke
Aug 30, 2017 04:27 PM
rpb396@sbcglobal.net
Mar 1, 2017 07:35 AM
cdrod
Jul 6, 2015 09:35 PM
BILL DEMMER
May 28, 2015 12:15 PM
