Clearing roller rockers?
you will need double gaskets with those for sure. I use the edelbrock 1/4" thick ( they are a bit thinner than the 1/4' quote) and glue them to the cover with silicone and glue between the gaskets also and let set till dry. Do not put anything on the bottom and you can use them over and over again. If you have the a/c and alt brackets they will still clear them.
P.S. make sure you use anti seize on the plug threads and remove and install cold.
junkyard72
Dec 30, 2013 07:16 PM
Vader
Aug 9, 2012 08:29 PM
