Clearing roller rockers?
Old Jun 25, 2015 | 04:20 PM
cdrod's Avatar
Rodney
Will these M/T valve covers clear adjustable roller rockers on ProComp heads?
Old Jun 25, 2015 | 05:07 PM
70cutty's Avatar
Beer Connoisseur
I have the MT covers and I use sce 179076 gaskets. They are extra thick, it clears just fine. Depends on the poly locks you are using.
Old Jun 25, 2015 | 05:16 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have the Edelbrock version, same height and they just clear with 1.72 ratio rockers on iron heads. I am using the discontinued Felpro Permadry valve cover gaskets.
Old Jun 25, 2015 | 05:47 PM
cutlassefi's Avatar
Just an fyi- Rocker ratio has nothing to do with it. As 70cutty said, if the poly locks are short enough you'll be fine.
Old Jun 26, 2015 | 06:35 AM
True enough, I guess Scorpion uses the shorter poly locks.
Old Jun 26, 2015 | 09:23 AM
cdrod's Avatar
Rodney
Small Poly-locks
Are these the small Poly-locks on my heads?
Old Jun 26, 2015 | 04:46 PM
Those look similar to mine.
Old Jul 6, 2015 | 09:35 PM
buzzbomb's Avatar
you will need double gaskets with those for sure. I use the edelbrock 1/4" thick ( they are a bit thinner than the 1/4' quote) and glue them to the cover with silicone and glue between the gaskets also and let set till dry. Do not put anything on the bottom and you can use them over and over again. If you have the a/c and alt brackets they will still clear them.
P.S. make sure you use anti seize on the plug threads and remove and install cold.
83hurstguy
May 3, 2015 07:47 PM
junkyard72
Dec 30, 2013 07:16 PM
AzChevs
Oct 8, 2013 06:26 PM
Vader
Aug 9, 2012 08:29 PM
Redog
Aug 14, 2008 06:56 PM
