Rear Tire size on a 68 442
Old Apr 21, 2013 | 04:48 PM
GoodOldsGuy's Avatar
442=A perfect 10
Need to know if a 15X9X30 drag slick will fit under a 68 442. Running Chevy Rallye stock steel wheel w/standard offset and stock rear.
My measurements show that they will just fit but before I pop for a pair I want to make sure of the fit. Maybe someone has done this before. Running pure stock class. Thanks
GOG
Old Apr 22, 2013 | 08:40 AM
70Wcars's Avatar
I ran 29.5 X 9 X 15 M/T Slicks on my 70 with stock width rear and 8" rims. No clearance issues.
Danny
Old Apr 22, 2013 | 08:43 AM
chadman's Avatar
I had a 28x10.5 MT slick on a my '69 with a 15x8 wheel w/4.5" backspace. The 68-69 cars don't have as much room as the 70 and up cars. The width will be fine. Where you may run into trouble is the height. It will be pretty close on the front edge of the wheel well.
Old Apr 22, 2013 | 09:06 AM
gearheads78's Avatar
car guy
As Chad mentioned the height is what I would be worried about especially as they grow during a run.
Old Apr 22, 2013 | 03:43 PM
olzman's Avatar
I ran this Hoosier on my car with 8" weld pro stars 4.5 back space with no problems
18212 9.0/30.0R-15 Radial*** C 9.0" 29.9" 94.0" 8-10" 8" 11.3" 22 C06
They make a smaller circumference at 92.5" also these are radial slicks between 17psi and 22 psi
Old Apr 27, 2013 | 06:19 PM
442=A perfect 10
Thanks guys, I have a friend who races and he has a set of Goodyears mounted on chevy rallye wheels. He will loan them to me for a trial fit. I will post what I find out.
GOG
Old Apr 27, 2013 | 08:33 PM
Run to Rund's Avatar
Wheel offset will be critical. Section width will be about .8" more with a 10" wheel than with 8" in case sidewall clearance to the frame, etc. is an issue.
Old May 11, 2013 | 06:00 AM
442=A perfect 10
OK....here is what I found out. A 30X9X15 will not fit due to rocker panel interference when you try to put weight on the axle. Sooo...I went with a 28X9X15 and I have no clearance issues. This is with a Mickey Thompson drag slick mounted on a stock offset wheel. Thanks for your input!
GOG
69 442 protour
Jan 17, 2015 09:18 PM
4-Speed
Wheels and Tires
May 13, 2010 03:21 PM
derek nesdoly
Jun 25, 2009 03:02 AM
69442
Apr 9, 2009 06:48 AM
BigAl72
Mar 16, 2009 06:16 AM
