Olds racing gears
Old April 14th, 2015, 07:21 PM
NHRA W-30's Avatar
Olds racing gears
Looking for a set of 4.66 ring and pinion { Olds 12 bolt rear - 31 spline axels } for my '70 W-30 NHRA stocker . Any one out there have any suggestions ? Appreciate any help !
NHRA W-30 is offline
Old April 14th, 2015, 07:37 PM
Contact 507olds (Brian Trick) or MONZAZ - they may have what you;re looking for.
Fun71 is online now
Old April 14th, 2015, 07:46 PM
NHRA W-30's Avatar
Thanks-- wiped out a set of 4.66 gears couple years ago and have been running 4.33 ratio currently . They are ok , but I miss the 60 foot and harder pull at the finish line.
Old April 14th, 2015, 07:50 PM
2blu442's Avatar
Matt had a set for sale with the posi carrier. Check out this thread:
https://classicoldsmobile.com/forums...-66-gears.html
2blu442 is offline
Old April 14th, 2015, 07:58 PM
oldsmobiledave's Avatar
How about 4.33?
https://classicoldsmobile.com/forums...ginal-box.html
NOS 4.33 gear set for sale if you can live with them
Can you post pics of your car and some details on your set up. Also what ET and MPH are you posting?
oldsmobiledave is offline
Old April 14th, 2015, 08:08 PM
NHRA W-30's Avatar
Have 4.33 now--- my 60' times are suffering . Currently 11.60's at 113 and change w/ a blueprinted 468 and a Dale Smith factory race cam . I believe it is the last 70 w-30 still running stock in California . Currently in F/SA trim.
Old April 14th, 2015, 08:12 PM
2blu442's Avatar
Matt had 4.66's for sale. If you haven't checked with him you should see if he still has those for sale. He said he'd sell them with our without the posi carrier.
John
2blu442 is offline
Old April 15th, 2015, 08:07 AM
pics
Pictures. We must have pictures.
If you can not post pics email them to me & I will post.
Dave
dlnicol@shaw.ca
Old April 15th, 2015, 09:56 AM
Rallye469's Avatar
Good lord!
What's your trap RPM with 4.33's & 4.66's???
-pete
Rallye469 is offline
Old April 15th, 2015, 01:53 PM
rktolds's Avatar
He contacted me. I sold mine awhile ago. Trap rpm when I was calculating for small block W31 clone was just south of 7000rpm.
rktolds is offline
Old April 15th, 2015, 02:08 PM
Tire size
Good lord!
-pete
You can stuff a pretty tall tire under a 70 442. What are the tire restrictions in that class?
Old April 15th, 2015, 07:05 PM
Chesrown 67 OAI's Avatar
I have a set of 466 here for sale. Also a 672 low carrier 31 spline for sale too. Will have both at Csrlisle. Also have a 390 r&p for a Type P rear.
Chesrown 67 OAI is offline
Old April 15th, 2015, 07:15 PM
Oldsmaniac's Avatar
When I used to bracket race my 67 4spd with 466's and 30 inch tall slicks I was going across the line at around 5900 rpm.
Oldsmaniac is offline
Old April 15th, 2015, 07:49 PM
gears
4.66
Old April 15th, 2015, 09:09 PM
NHRA W-30's Avatar
Thanks for responding -- My father raced for the factory late 60's and early 70's and new Ron Garey and the Chesrown guys well . His '67 W-30 is what got him the deal w/ Dale Smith and Olds. He ran the Manarina Olds cars out of western N.Y. Have a couple leads on 4.66 gears ---But sometimes folks don't know what is real or not . May get back to you re: yours . Thanks--- Brian Ranks
Old April 15th, 2015, 09:38 PM
NHRA W-30's Avatar
426 passes over 4 year w/ 4.66 gears hitting 6800 RPM at the stripe . After I cleaned off every tooth on the ring gear one nite, I could only find 4.33's ---- w/those I cross the line at about 6300 RPM
Old April 16th, 2015, 05:55 AM
Brian. I met your dad in engiishtown 68 when we eon stock. He won D/S and was eliminated by Ron in bracket. Yellow 67, just like my white one, only mine was automatic. Small world. This set I have is almost new, very few runs.
Old April 16th, 2015, 03:39 PM
BlackGold's Avatar
Wow, that's impressive for a 455 stocker. I'd like to know your engine builder's secrets.
BlackGold is offline
Old April 16th, 2015, 05:22 PM
RandyS's Avatar
I didn't think a big block would turn those revs in any case............
RandyS is offline
Old April 16th, 2015, 08:28 PM
NHRA W-30's Avatar
That motor was built by my father and I in 2005 for $1600 plus our labor. Pretty basic stocker blueprint w/ 95% OEM parts we had kicking around . At that time, some of the parts were still available to buy. When I replaced it in 2009 Nothing was left for new parts to buy at any price-- the result being I had to provide OEM specs on any things and have them c&c made for me . Cost jumped to $7500 plus our labor . Pops has built many stock and super stock record holders over the years.
Old April 19th, 2015, 08:04 AM
Pics
Posting these for Brian for all to enjoy.
Dave
Old April 20th, 2015, 03:32 PM
BlackGold's Avatar
Very nice!
Old May 18th, 2015, 07:18 PM
davebw31's Avatar
With 5:00 gear and Liberty pro-shifted 2:64 Super T10 4 speed, and 30X9 tire, shifting at 7,000 rpm (SBO 359 C. I. W31) I went through the traps at 6,600 at 114.5 mph. Needed a 5:13 or 5:38 gear if only NHRA allowed 12 bolt chevy rears at the time, which wasn't allowed till after I quit!
davebw31 is offline
Old May 18th, 2015, 07:38 PM
NHRA W-30's Avatar
Dave-- My Dad ran a set of 5.38's in his '69 W-31 super stocker for a bit that year . Still have them , but a little too tall for my 455 stocker . Found a set of 4.66's through this post recently. Will put them in this fall after I finish freshening up the motor . Have taken most of this season off and want to come back w/ a bit quicker package . Looking to exploit a couple gray areas in the stock rulebook as well as switch to aluminum radiator { OK 1st time this year } .Set up for F/SA now but want to run E/SA next year as well .
Old May 18th, 2015, 07:43 PM
curious
Were 5.13 & 5.38 gear sets only available to race teams or were these gear sets from aftermarket suppliers?
To my knowledge there were 4.33, 4.66 & 5.00 gear sets available @ the parts counter but I have never heard of these other 5 series gear sets.
Old May 18th, 2015, 07:51 PM
NHRA W-30's Avatar
Dave-- You are correct -- The 5.38's were given to the Olds factory drag teams by Dale Smith of Olds R&D . Don't know exactly how many were made , but it's possible that you could count them w/ your fingers and toes ! Late '68 -- to maybe early '70
boc23
Drivetrain/Differentials
August 29th, 2014 02:23 PM
monzaz
August 7th, 2014 11:12 AM
monzaz
May 29th, 2010 08:46 PM
Quick Reply: Olds racing gears
