New Olds Rockers
Old Apr 30, 2021 | 11:07 AM
cutlassefi's Avatar
New Olds Rockers
Hey Guys
I’ll be offering another new Olds specific engine part very soon. This time it’s a new rocker arm made by Harland Sharp but different than their current stud mount Olds specific rockers.
It’ll have their Diamond cut feature and have the ratio and “Olds” etched on each one. (Per photo). They’ll be available from me only for the next year in three ratios, 1.6, 1.65, and 1.7. Price will be $440.00 a set shipped.
Forging ahead!!
(Btw, this is NOT the “epitome of cool” project I eluded to in another post, that’s still to come)😉
Old Apr 30, 2021 | 11:17 AM
66SportCoupe's Avatar
That's sweet Mark!
Old Apr 30, 2021 | 12:16 PM
chadman's Avatar
What is the advantage of these over the current 5016 and 5017?
Old Apr 30, 2021 | 12:48 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I just bought the first set! Letting Mark pick the ratio to go with the roller cam he is doing for me.
Old Apr 30, 2021 | 12:52 PM
08-141 K43727's Avatar
Pretty cool!!
Old Apr 30, 2021 | 01:23 PM
cutlassefi's Avatar
Fair question.
Diamond cut makes them lighter without sacrificing strength.
They do it on SBC, BBF and Pontiac’s currently.
Plus I had someone ask me if they could use their HS rockers on the new Edelbrock head. I asked him which ones he had. He didn’t know, no markings. Had to send a pic to HS to make sure.
Old Apr 30, 2021 | 01:44 PM
skyhigh's Avatar
1972 Cutlass Town Sedan
Will these have the short poly locks Mark?
Old Apr 30, 2021 | 03:39 PM
cutlassefi's Avatar
Std length, 1.125”.
Old Jan 13, 2022 | 06:14 PM
Andy's Avatar
Mark,
can-you use these 1.7 rockers on a factory head and would that essentially give you a little more cam lift and or duration?
Old Jan 14, 2022 | 06:04 AM
I discussed using these on #6 iron heads with Mark. He mentioned the rocker pads need milled first, .100", I believe. I used 1.72 ratio Scorpion Ford Windsor rocker arms when using a small 204/214 cam on a 9.6 to 1 350. The push barely cleared the heads, something to watch for with a higher ratio. I went from Comp roller tips to true rollers, most of the gain was probably there, just quieter, no seat of the pants gain. You will gain lift, duration is so little, it won't fix an improper cam choice. These rockers are very nice, I can hardly wait to put them on the Edelbrock heads they are designed for. Remember these are 7/16" studs, your iron heads would also need tapped for them. The HS poly locks vs a basic Comp replacement in one pic.
heatmup
Aug 28, 2020 07:46 AM
70442rag
Nov 13, 2018 04:19 AM
71DP
Jul 2, 2017 03:11 PM
CanadianCutlass
Jan 11, 2015 07:07 AM
