new carb car wont start
Old Sep 19, 2012 | 08:26 PM
oldsmoboogie's Avatar
ok so i just installed a brand new out of the box holley street hp 850 carb and now the car wont start. It ran great i took off the carb put the new one on and now it cranks i can see fuel out of the squirters but no fire. I dont know why but it seems like there is no spark but i didnt touch anything but the carb any suggestions? Im supposed to hit the drag strip fri night and im running out of time.
Old Sep 19, 2012 | 09:22 PM
ah64pilot's Avatar
Do you have a picture of your engine bay? It would help to know where your coil is mounted, maybe you knocked the coil wire loose when you put the new carb on.
Old Sep 20, 2012 | 04:37 AM
bkeese's Avatar
If you've got gas (and you say you do) and you've got spark then you'll have noise. No noise = no spark. Check for 12 volts at the coil. Mine did the same thing, issues with the ignition switch. I ran a wire straight from the battery to the coil (hot wired) and she fired up.
Old Sep 22, 2012 | 09:57 AM
When i was tryn to start the car i only had a few mins to mess with it and it seems it may have been flooded and wouldnt start. I had a friend come over while i was at work and he got it going. He said the air fuel mixture screw was only half a turn out. He had to turn it out more to get to run well. The directions state you shouldnt have to adjust the screws. At the track when i floored the pedal the car did nothing for about half a second then left hard so now im wondering where to start to tune the carb so it doesnt hesiate any suggestions are greatly appreciated.
Old Sep 22, 2012 | 10:27 AM
Tony72Cutlass'S''s Avatar
I bought a BRAND NEW carb from the factory, and guess what, wouldn't start the car.
First preliminary check: FLOAT HEIGHT.
If your float(s) aren't set correctly, you'll never start that thing.
Pour a couple ounces of gas down the primaries and see if she fires.
1lowdelta88
Jun 4, 2015 11:29 AM
OldManTucker
May 2, 2015 05:03 PM
scooter123
Apr 4, 2013 08:29 PM
nj_cutlass72
Sep 4, 2012 08:39 PM
tnelson
Sep 10, 2010 05:42 AM
