Let’s Build A Turbo Small Block
I am not on the hook for the rods and pistons, the owner admitted it was his issue. I have offered the 330 crank I have if it can be offset ground enough for those rods and pistons to work. Does anyone know if you can offset grind a 330 crank to a 3 5/8” stroke? Now that his machinist is gone I don’t know he is going to get this done anyway. This really sucks because these two gentlemen are very well respected in our community. They did very well racing Oldsmobile’s in the late 80’s early 90’s. I just don’t know to do at this point, the project has already been delayed too long.
Uhh you put good rods in it but kept the same stock main bolts? Why?
And you did check the clearance between the rod and pin boss in the piston correct? Those rods are offset, std Old rods are centered. Just an fyi.
And whether they’re floating or not doesn’t matter. You need to make sure you have enough clearance between the small end of the rod and the pin boss.
