Best casting numbers for BBO block & crank?
Old Nov 24, 2014 | 07:17 AM
Fullsizelover's Avatar
I am currently halfway through my parts list (Lunati roller cam kit / Eagle Rods / Edel Intake / Comp Rockers) so I am only missing the pistons and new alu heads to finish it up.
Of course I could just use the same '76 block 455 I have now but maybe to make things more easy, what would be the best block and crank castings to look for if I build it from the ground up?
Since I just noticed an add for a guy who sells blocks and cranks:
http://link.marktplaats.nl/m867269943
Old Nov 24, 2014 | 01:13 PM
cutlassefi's Avatar
'76 block is fine. Look for an "N" crank and you're good.
Do a search, I did a 455 for a guy on here, stock Procomp heads, Custom Lunati roller, etc, Made 493hp/564tq.
Let me know if I can help.
Old Nov 24, 2014 | 04:54 PM
GOSFAST's Avatar
Eagle Rods "Tip"
If you are using the stock 455" components you will need to clearance-grind the block at the lower cyl bores for the Eagle rods, they will not clear without the grinding!
Thanks, Gary in N.Y.
P.S. Just went down this road recently on a 100% stock-appearing deal!
Old Nov 25, 2014 | 11:07 AM
m1fresh's Avatar
I just picked up a 455 casting#396021F F1 bare block, looking to do a stock build.
what would be the best crank for this set up?
thanks guys
Old Nov 26, 2014 | 07:30 AM
cutlassefi's Avatar
[QUOTE=cutlassefi;766473]Look for an "N" crank and you're good.
QUOTE]
toplot
Aug 18, 2015 08:17 PM
Al2011
Apr 18, 2014 11:14 AM
delta881972
Aug 24, 2008 09:19 PM
paige_dart
Nov 12, 2007 09:40 AM
omega73
Aug 17, 2006 07:24 AM
