cracked oil pan
Old Apr 27, 2025 | 05:41 PM
w30442's Avatar
cracked oil pan
Got a crack in my pan at the front. Anyone else have issues with cracked pans. Kind of a strange place for crack but must be some stress. Anyone else get a crack in this location ?
I plan on drilling a hole in the ends of the crack and welding it up.
Glen
crack in pan
crack in pan
Old Apr 27, 2025 | 05:48 PM
Never heard of that before. Is it an OE pan or aftermarket? I bought a Moroso deep sump oil pan from Summit and it leaked fluid out of the drain plug when sitting on the engine stand. I swapped it for a Milodon pan that worked great.
Old Apr 27, 2025 | 06:51 PM
w30442's Avatar
Its an aftermarket Milidon pan
Old May 1, 2025 | 10:37 AM
BillK's Avatar
Is it a crack or a gouge ? Hard to tell from the picture.
Old Jan 11, 2026 | 07:19 PM
oletrux's Avatar
@w30442
Can you explain how you welded it on the car, and special precautions you might recommend?
Thx.
Old Jan 14, 2026 | 04:06 PM
68post's Avatar
Is it mounted to a flexy-block 455? I've heard of them cracking on the bottom (Milodon).
Old Jan 14, 2026 | 04:13 PM
w30442's Avatar
Oletrux - The engine is removed from the car. Drilled holes in the pan where the cracks ended to keep them from growing further and welded it up with a Mig/ Tig would of done a nicer job but I used what I had. Tested it with water over a few days and no leaks.. I also removed the pan to do this of course.
Old Jan 14, 2026 | 04:26 PM
oletrux's Avatar
It tore the seam along the backside of the pan. Thanks guys, but I'm going to replace it. We travel long distances in this car and really need to maintain the highest reliability that I can.
Thanks again.
Gene kerr
Jul 24, 2022 06:17 PM
69Chrgr
Jun 22, 2021 03:17 AM
george landis
Aug 16, 2019 03:26 PM
yellowrocket
May 28, 2019 03:13 PM
brandon 455
Mar 29, 2014 01:49 PM
