builds
Old Jun 12, 2015 | 02:15 PM
captjim's Avatar
builds
There was a recent thread (since deleted) involving compiling engine and car builds. There was some disagreement regarding the particulars, so I thought I would try this. Let's have a thread with proven builds posted, one thread with a bunch of both vehicle and engine combinations. Anyone who is interested can post their build, regardless of the performance level, as long as there is some type of documentation regarding performance; track results, dyno sheets, etc. This is not for "bragging", the idea is to have a list of proven combinations of all performance levels so that those planning or researching a similar build can get some ideas of what to expect and how to budget.
PLEASE, to keep the clutter down, no comments on the builds, even if positive, let each post stand alone as a post. PM the poster if you would like more info. Then others can copy/paste or refer to it if the subject comes up.
Old Jun 12, 2015 | 02:16 PM
captjim's Avatar
9 to 1 Olds 355 street build
Olds solid web 350, bored .030, zero decked
Crank turned .010, stock rods, clearances .0025 on crank, .0022 on rods Balanced
Sealed Power pistons, 23 cc dish
#7 heads, stock valves, 5 angle valve job, mild port work, milled to 60cc
Engle 16-18 cam .472/.488 210/216 on a 112, installed straight up.
Cloyes chain
Pertronix Flamethrower HEI, stock weights, 1 light, 1 med spring,
timing 23 BTDC
Performer intake
Holley 670 Street avenger carb with 50 cc pump
Sanderson shorty headers, 1 5/5 primaries, 2.25” dual exhaust with Dynomax Super Turbo mufflers
Turbo 350 with Coan custom nitrous converter, 2600 stall
8.5” GN posi rear 3.42 gears, Lakewood lowers, Umi adjustable uppers M/T drag radials
83 Cutlass wagon, 3820 lbs with driver
Naturally aspirated 13.91 @ 98.12 with 2.033 60’
With a 100 HP shot of nitrous, 53/57 jets 12.78 @ 103.67 with a 1.773 60’
http://www.dragtimes.com/Oldsmobile-...lip-10876.html
Old Jun 13, 2015 | 05:19 AM
coppercutlass's Avatar
Chevy budget Olds powered
I'll join in the fun.
350 olds 10 to 1 compression
comp 280h 490/490 230/230 @ .050
#6 heads by rocket racing ( just big valves 2.07/1.63 )
cast flat top pistons
comp timing chain
prw roller tip rockers
edelbrock rpm intake
edelbrock 600 cfm carb
proform hei running 34 degrees total
full length headers with x pipe
th400 with 2200 stall
3.73 gears running 26in. tal drag radials
bone stock suspension
car 1972 cutlass, appx. 3600lbs with driver
Best e/t was 13.3 @ 103 with a 2.02 60'
Old Jun 16, 2015 | 03:15 PM
chadman's Avatar
I'll wait for the official section with standards.
Old Jun 16, 2015 | 03:49 PM
Better put on a pot of coffee then.
Old Jun 24, 2015 | 05:52 PM
67 Cutlass Freak's Avatar
Milan's Ported Iron Head BB 527HP Pump Gas
Big thanks go out to Milan for helping Don, (80 Rocket), & myself, for building this stout, pump gas, stealthy street thumper. We have been working together to test out the capabilities of a healthy, mildly ported, iron head, pump gas engine.
Here's some details:
Early 425 block with .921 lifter bore
CN crank
Standard back cut Dura-Bond cam bearing , I add a small hole that I install at 6 o'clock and put the larger Dura-Bond hole at 3 o'clock , I feel the small hole at 6 o'clock helps on start up where the cam sits at rest , no restrictors.
Poor mans windage tray , cutting and welding stock Olds tray to eliminate the open area in the middle , also you can see lifter bore (.021)restrictors , Schubeck ceramic lifters are hollow and need to have restrictors installed.
Crank is internally balanced(also is a stick shift crank) , it needed 4 slugs of mallory , these are the front two , ARP main studs torqued to 110 lbs with ARP lube.
12point ARP nuts for oil pump(oil pump pressure is set at 70psi @ full by-pass)
Eagle rods(rod bolts are stretched to .006) , bearing clearances are .0025 rods , .0032 mains , side clearance .018 .
Pistons are ICON 25cc dish , for a very safe pump gas motor , 9.7:1 comp.
Cam is a Bullet 242 - 256 -112 in @ 109 .365 Mopar lobe on the intake , will make .600 lift with a 1.7 rocker. ,372 Ford lobe on the exhaust will make .575 lift with a 1.6 rocker. This is the same cam as in the stock "C" head motor.
Carb is a 950 Holley Ultra with a 1050 Quick fuel body( 1.585 ) profiled venturi's and BLP custom boosters. Emulsion package changed and idle feeds lowered.
Headers are 2 inch Super Comp , 20 collector.
Cylinder heads:
Cast iron "C"s - Edelbrock swirl polished, back cut stem stainless steel valves. The intakes were cut down to 2.10" and the exhaust are 1.68" back cut 30 degrees,
Raised the intake roof .150", raised the exhaust roof .100" widened as far as I could without punching through, pulled all the bowls back, welded the exhaust dividers, pollished the combustion chambers/ 78 CC after .015 clean up mill, straightened the short side radius, squared the edges, tear dropped the guides, removed all the bumps, opened up the push rod holes on top for the 1.7 rockers usage, redid the valve job, lapped all the valves, de-slagged the exterior, deburred around oil return holes, Viton seals, 5/16" push rods
With well ported heads Pipemax thinks 511 minimum HP .
Big thanks goes out to Kevin Engelking from Engelking's Dyno Service. Kevin really knows his **** and was very patient with us to maximize this combination.
This was our best pull -
527HP/ 520 lb/ft Max
I thought this overlay was really cool. This shows basically same short block/ same cam/ same dyno/ same heads before and after porting-
We saw a 45 HP gain after porting and the peak power came in 400 RPM higher. We all had a great time, learned a lot and all in all I think this is pretty impressive.
You can see more details about the head porting here -
http://realoldspower.prophpbb.com/topic7569.html
This engine really sounded great and performed just as expected. Milan really knows what it takes to make these Olds sing. This engine is FOR SALE!
You could be the happy owner.
Old Jun 24, 2015 | 06:57 PM
That's awesome. I think you need that engine for the 67 dave lol. I can't wait to run the heads you ported for me. Should make the 355 I'm building really be something else.
70 cutlass s
Non-Olds Engines
69
Jul 11, 2011 02:24 PM
FTolliver
Jan 30, 2011 02:04 PM
import extermination
Nov 6, 2010 07:37 PM
t/a formulas
Mar 11, 2010 10:57 AM
gearheads78
Jan 9, 2010 12:43 PM
