BBO heads
Old Jun 20, 2013 | 07:20 PM
brandon 455's Avatar
BBO heads
I currently have c heads on my 455. I was looking for some aluminum heads and I run across the procomp brand. Has anyone run these, or would the edelbrocks be a better choice?
Old Jun 21, 2013 | 08:19 AM
cutlassefi's Avatar
Procomps are fine. If you looking for the last little bit of hp then the Edelbrock may be better as they have a different combustion chamber.
But either way they're both waaaay better than stock irons. I'd do the Procomps in a minute. Contact Bernard Mondello in Ca, he'll set you up right.
Old Jun 21, 2013 | 10:30 AM
380 Racer's Avatar
So Mark, the Pro Comps started out as a SB head? Was that because of the fuel pump fitting. Chambers? Are they big for a SB or small for a BB? Just curious.
Old Jun 21, 2013 | 01:32 PM
Okay thanks for the reply. The price difference is what was kinda scaring me about them. I was always told you get what you pay for and I didn't wanna buy a set of heads and they be no good.
Old Jun 21, 2013 | 02:11 PM
cutlassefi's Avatar
No same as the original Edelbrocks. They were designed for a big block first but will work on a small block with the right combo and electric pump.
Old Jun 21, 2013 | 03:14 PM
380 Racer's Avatar
So they still need an electric pump also. (wouldn't bother me at all) OK thanks.
QS442
Aug 12, 2014 05:56 PM
Al2011
Aug 8, 2011 01:41 PM
geckonz08
Nov 1, 2009 06:03 AM
442_rocket
Jul 19, 2008 08:43 PM
GoldOlds
Nov 16, 2007 05:56 PM
