Will 7a SBO heads fit 1976 or earlier 455 BBO
Old Aug 2, 2011 | 01:46 PM
Al2011's Avatar
Will 7a (small a) SBO heads fit 1976 or earlier 455 BBO. Any mods needed. I'm only asking because I found a shortblock but I only have my 350 7a heads available at the time. Also there is a rebuilder here locally that sells 455 rebuilt with heads for $1800. You think a motor for that price will make a good street weekend performance motor or should I just rebuild my 350 with performance parts?
Old Aug 2, 2011 | 03:24 PM
gearheads78's Avatar
car guy
No but there are a set of C heads on here for sale.
https://classicoldsmobile.com/forums...eads-pics.html
Old Aug 2, 2011 | 04:02 PM
72442clone's Avatar
My '72 455 has #5 small block heads on it which have larger valves installed, and runs outstanding producing all sorts of power and good compression. These heads were on it when I bought the car, and haven't changed them yet. I'll be getting some Edelbrock perfomer series heads as soon as I can afford it.
Old Aug 2, 2011 | 04:07 PM
I believe that the SB heads will physically bolt on, but you will have to contend with smaller valves, smaller ports, and using the smaller SB exhaust manifolds. You'll wind up with a sort of a Frankenmotor that nobody will be really sure how to tune right.
Probably not worth it.
Old Aug 2, 2011 | 04:48 PM
car guy
Yes they will bolt on but you have small chambers and mega shrouded valves.
Old Aug 2, 2011 | 04:49 PM
Again, bumping compression at the expense of valve and port size is usually NOT a good trade. Yeah, it will run, but it won't be all it can be.
Old Aug 7, 2011 | 07:47 PM
oldsy's Avatar
olds403guy
What amount of hp do you get?Is the rest of the motor stock?I have 70' 350 heads and a 71' 455 so im looking to see if that would make a good combo.thanks.
Old Aug 8, 2011 | 01:41 PM
72442clone's Avatar
I have about 550 hp at the flywheel. The rest of the engine is not stock. It does produce high compression and high horsepower, but like Joe said I do suffer from lack of flow through these heads. That's why I want the edelbrock performers...I think I'll boost my power up significantly.
The #5 heads on my 455 were built by a shop which designs racing engines. They installed larger valves, etc.
QS442
Aug 12, 2014 05:56 PM
bccan
Jun 22, 2014 09:56 PM
halfmoontrail
Jan 24, 2014 03:02 AM
coldwar
Jul 19, 2009 07:50 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
