'66 400 Roller Rockers
Old Sep 29, 2013 | 10:29 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Who's roller rockers should I use for my '66 400 build? I want reliability, gonna be a cruiser, occasional hot rodding, they will be going on Edelbrock heads.
Old Sep 29, 2013 | 11:42 PM
Erinyes's Avatar
Harland Sharp. They're a little pricey, but if you want reliability, you'll get it.
Old Sep 30, 2013 | 07:18 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Harland Sharp #5016 or 5017 is the best fit for the Edelbrocks.
Old Sep 30, 2013 | 07:38 AM
x3, do a search on poly locks for the shorter set.
Old Nov 4, 2013 | 07:08 PM
66 Olznut's Avatar
I did a search and it says the 5016 or 5017 is for Bulldog heads and 5003 is for Edelbrocks. Is there a difference?
Old Nov 4, 2013 | 09:02 PM
copper128's Avatar
Lt. Buzzkill (ret.)
The p/n for Bulldogs is the best fit for the Edelbrocks. Several top engine builders have confirmed they produce better geometry than the 5003.
Old Nov 5, 2013 | 04:08 AM
cutlassefi's Avatar
Yes the 5016 or 5017's are the best fit. The rocker is about .050 longer on the valve side to better accommodate the taller valve heights on the Edelbrock heads.
However the Scorpion Ford Windsor rockers work fine as well.
Old Nov 5, 2013 | 04:13 AM
380 Racer's Avatar
I also used 5016 on my RR heads.
Old Nov 5, 2013 | 06:33 PM
66 Olznut's Avatar
Thanks again guys.
Old Dec 10, 2013 | 08:35 PM
66 Olznut's Avatar
One more question, will these rockers fit under the stock valve covers?
Old Dec 10, 2013 | 09:38 PM
64Rocket's Avatar
The rockers fit fine, it is the poly locks that are the problem. You should get taller valve covers. there are spacers to use with stock covers or I have in the past use the thick gaskets and doubled them.
Gene
morrowjm4154
May 20, 2009 02:46 PM
65Delta88
Dec 4, 2008 02:02 PM
timothypaul
Oct 26, 2008 08:03 PM
Redog
Aug 14, 2008 06:56 PM
70OLDS442
Nov 21, 2007 05:00 PM
