557ci Rocket Build
Old Nov 7, 2025 | 03:52 PM
cutlassefi's Avatar
557ci Rocket Build
I’m doing two of these for a customer. This is the first of the two;
4.390 bore Racetec pistons
4.60 stroke Bryant billet crank
7.00” K1 rods
2x4 Sniper setup
Old Edelbrock low rise 2x4 intake
Ported Gen III Edelbrocks
9.8:1
238/246@.050 hyd roller
561hp/640tq
This intake isn’t the best, especially when it’s trying to feed 557ci. Good tq, not a lot of hp. Needs bigger headers too. BUT, the torque comes in early and strong. It’ll probably break a few driveline parts!!
Old Nov 9, 2025 | 06:49 AM
Mr Nick's Avatar
At first I thought it was the first engine of two, for a boat. But I assume from the front drive that isn't the case? Can you share what the engine(s) are going into?
What do you think it would make with a more well suited intake and headers?
Old Nov 9, 2025 | 02:44 PM
cutlassefi's Avatar
This one is going in an early 70’s A body.
A good victor with a 950 would make well over 600, it made 582 with an out of the box Victor and a 750 during break in.
But this is a relatively mild build, good not great heads and not a lot of cam for 557ci build.
Old Nov 10, 2025 | 05:55 AM
CustomBruiser's Avatar
Why the small cam? Is this a street car and not a race car?
Also, nice build and nice looking engine.
Last edited by CustomBruiser; Nov 10, 2025 at 05:55 AM. Reason: To add a compliment
Old Nov 10, 2025 | 07:24 AM
SteveDB's Avatar
Stuck in the 80's
Thanks for sharing, always interesting to see different builds.
Old Apr 22, 2026 | 02:44 PM
cutlassefi's Avatar
Update;
No more Snipers as there isn’t support for those anymore.
Instead it got (2) 800 Cfm AVS 2 Edelbrocks and a Progression Ignition Dist.
Final numbers are 575hp/653tq. Actually I did a lower pull that made just shy of 660 at about 3000rpm. Dyno sheet to follow.
Note; any of you that still think you need an ignition box for a street or street/strip build of this power level are fooling yourselves. This is an electronic Dist, with a $50 coil. Didn’t miss a beat to nearly 6000 rpm.
And another myth busted, wait till you see the BSFC between these carbs and the Sniper. Some of you will be surprised, I wasn’t.
Old Apr 22, 2026 | 07:44 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Interesting build. No more support for the Sniper? Is it because they Gen 1? How did you like the AVS2?
Old Apr 22, 2026 | 07:59 PM
cfair's Avatar
I'm not much of an engine guy, but those look terrific and it's fun to learn what you're doing all these decades after these blocks stopped being cast.
Also great to hear you like the Progression Ignition distributors. I've used them in 2 big cars and they're a real step forward over weights, springs & vacuum cans. I hope they're making a profit so they'll be around long term. The product is great for us amateurs.
I still have a soft spot for quadrajets, but I'm a computer guy so I keep watching the multiport EFI space and debating whether to make the leap. But then I look at my simple mechanical qjets, check the O2 sensor lambda values and wonder whether EFI would really help me $2,500 bucks worth. Guess I'm cheap. Or sentimental, or both...
Anyway from far away, great to see your builds.
Chris
Old Apr 23, 2026 | 05:42 AM
cutlassefi's Avatar
Yep, Sniper 1 is done.
Haven't used one of these carbs in a while. It was pretty good right out the box, but did need a rod and spring change.
I spent more time on the timing curve and valve lash instead of the carb. A welcome experience.
Old Apr 23, 2026 | 07:26 AM
GN1220's Avatar
Looks similar to one some dumb kid built right after high school. Ran good while it held together.
chadman
Jan 30, 2025 04:36 PM
cutlassefi
Oct 20, 2024 03:04 PM
cutlassefi
Apr 25, 2021 10:50 AM
citcapp
Oct 2, 2011 12:22 PM
dman0712
Dec 30, 2009 12:13 PM
