455 Oldsmobile Build
Old May 26th, 2022, 10:20 AM
  #201
Battenrunner's Avatar
Originally Posted by Bernhard
How efficient the car uses the HP/TQ is a big factor in ET goals. The less efficient the car the more HP/TQ required to run mid 11's.
coppercutlass car is an example of an efficient use of HP/TQ on a budget.
100% agreed!
I know of a certain racer who took a used stock 455 out of a Toronado with C heads, performed a valve job and honed the block and installed new rings, and used a Lunati “Stocker” cam.
This was all in an F-85 with a good converter and 3.73’s I believe. Solid 11 second combo.
Battenrunner is offline
Old May 26th, 2022, 03:40 PM
  #202
VORTECPRO's Avatar
Well said
VORTECPRO is offline
Old May 26th, 2022, 03:41 PM
  #203
VORTECPRO's Avatar
Originally Posted by Battenrunner
100% agreed!
Yes...it 4.10 gears and a BAD converter LOL
Old May 27th, 2022, 06:10 AM
  #204
New2oldsw30's Avatar
100% agreed!
So it looks like I will be an Olds 442 owner soon. Car is a tribute W30 with pretty much ALL the W30 stuff transferred over from a wrecked 1970 W30 EXECPT for the VIN, Trans and W27 rear. At this time, it's ALL OEM W30 stuff but .030 forged pistons and 800 Holley with headers. Not to sure I can get this whale to run mid 11's with the F heads and OEM W30 intake with stock or non-hi stall converter. Would consider swapping to the ported Speedmasters of Cutlass EFI, but would like to keep the original intake?? Or do I sell off the OEM F heads and intake for Speedmasters and RPM air gap???
So with that being said, what was the combo to make this lighter F85 run solid 11? Would like to do it with 3.08 or 3.42 gears? BUT could swap i to more gear and overdrive trans, 4L80/700R4 or even consider a gear vendor which for the $$$ might be the best way to go.
New2oldsw30 is offline
Old May 27th, 2022, 06:11 AM
  #205
BTW, Hi Mark,
Old May 27th, 2022, 06:17 AM
  #206
VORTECPRO's Avatar
"So with that being said, what was the combo to make this lighter F85 run solid 11? Would like to do it with 3.08 or 3.42 gears? BUT could swap i to more gear and overdrive trans, 4L80/700R4 or even consider a gear vendor which for the $$$ might be the best way to go"
Not if you want a 11 sec Olds...............................maybe the gear vendor
Old May 27th, 2022, 06:25 AM
  #207
Old School Olds
tru-blue 442's Avatar
tru-blue 442 is online now
Old May 29th, 2022, 10:45 AM
  #208
CANADIANOLDS's Avatar
No..........but no Olds expert here. I do know one thing, there was a Brandon Bakies 455 stocker build I posted a while back I thought made around 507 HP, I couldn't see why my build would make less but really had no idea.
https://youtu.be/ugYQgIuKc5Y
that low compression G/SA stocker has run an 11.16…pretty impressive .
For those that don’t know…factory intake, valve lift rule, G heads and factory weight 😎
CANADIANOLDS is offline
Old May 29th, 2022, 10:57 AM
  #209
508@5800 575@4000 clearly has the suspension figured out. Your 455 in this chassis would be deep into the 10’s
Old June 2nd, 2022, 09:19 AM
  #210
What was the lifter part number for this, if you do not mind sharing? Lift of cam as I can't find anything on redline site about cams?
Old June 3rd, 2022, 06:16 AM
  #211
VORTECPRO's Avatar
I used Morel lifters, the cam was 232 @ .050, my cam grinder Spiro isn't open to the public so it will be hard to find any information, but if you were to call him and ask him about the cam he made for me I'am sure he would fix you up.
Orlando 1
July 4th, 2020 02:14 PM
yogieb123
October 6th, 2014 11:21 AM
Jolly Green
July 4th, 2014 08:19 PM
Jolly Green
July 24th, 2013 12:16 PM
neoinbiz
November 6th, 2006 12:11 PM
Quick Reply: 455 Oldsmobile Build
