350 Hi Vol water pumps?
Old Apr 21, 2025 | 09:36 AM
928sport's Avatar
Who has used one and what brand is the best out there?
Old Apr 21, 2025 | 02:27 PM
70sgeek's Avatar
'72 Cutlass ragtop
I use Milodon p/n 16285 - works great on my '72 350 - note the length of your pump to be sure you buy a correct replacement for your pulley alignment. For this one - Notes: 6.000 in. water pump length
https://www.summitracing.com/parts/MIL-16285
Old Apr 21, 2025 | 04:16 PM
928sport's Avatar
Thank you.
Old Apr 22, 2025 | 06:59 AM
oddball's Avatar
There's only two options if you have a 6" pump: Milodon and Flowkooler. Milodon appears to still be using the very early design where they take a stock pump and just weld a plate on the back of the impeller. You generally have to use 2 gaskets to get some space between that plate and the timing cover. Flowkooler used this design initially also.
The Flowkooler pumps are also just stock pumps but with an aluminum impeller with many small non-directional blades.
Flowkooler is also available in shorter lengths.
Is it really worthwhile? Probably not. Increasing flow from a pump is unlikely to actually change cooling performance, especially if you're running a stock style thermostat.
I'd recommend just getting the GMB aluminum stock replacement. Bearings and seals still fail regardless of how much you spend - they're all coming from the same factory - so might as well keep it reasonable to replace.
Or, buy the fancy pump once then swap out the impeller on your replacement pumps. A little bit of heat from a propane torch is enough for the impellers to slide right off and on.
Old Apr 22, 2025 | 07:24 AM
SteveDB's Avatar
Stuck in the 80's
Do you have thoughts on the ideal space between the impeller and the timing cover? I have heard around 1/10" from the Pontiac folks that have to adjust their covers....
Old Apr 22, 2025 | 09:01 AM
928sport's Avatar
Thank you.
Old Apr 22, 2025 | 06:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I used the old style Flowkooler pump. Honestly didn't do anything. The impeller is farther away from the pump wall than a factory closed impeller water pumps. I am currently using the new style reverse rotation Flowkooler water pump. The impeller is definitely an improvement over the riveted plate. Whether it actually helps with cooling is hard to say.
Old Apr 23, 2025 | 05:58 AM
oddball's Avatar
Just wherever it can sit where it doesn't hit the timing cover and doesn't hit the pump body.
Sure, for best flow and minimum cavitation there should be a specific spacing, but this is beyond even splitting hairs. Swatting flies with a hammer. Whatever metaphor works for you, but that's going waaaay down the rabbit hole to worry about water pump impeller spacing.
The factory cast impeller is almost assuredly the best impeller but they're not falling off trees. The riveted plate impeller was a real hack and thankfully I don't think that design was used very long. Heh, I forgot about that.
Dkono
Jan 14, 2025 08:18 PM
jozw30
May 21, 2021 07:14 PM
350_rkt
Jul 4, 2019 11:08 AM
brandon reynolds
Dec 14, 2013 08:50 PM
HWYSTR455
Jun 30, 2013 07:41 AM
