2 piece timing cover
I made one off stock cover. Bent a little piece of sheet metal into roughly a soft "z" channel & tacked it onto upper half. Acts as sort of a canopy over the joint + forms a trough/dam to help retain bead of RTV. Doesn't leak & have no plans to use it, just a MAW that has been transferred from engine to engine.
[QUOTE=honkeycat;1052749]Unless your changing cams all the time, not needed[/QUO
LoL
maybe you would like to change your cam degree / timing
if you do your 2 piece right
you can keep water pump bolted to the up segment
LoL
Almond900
November 1st, 2016 09:29 PM
Mr Nick
November 10th, 2012 09:33 PM
Indy_68_S
Brakes/Hydraulic Systems
January 2nd, 2011 09:23 AM
