detent switch
Old Oct 16, 2015 | 02:18 AM
sortasane's Avatar
detent switch
I need a firewall mounted detent switch for my 66 olds cutlass convertible. Can anyone help? Pedal mount switches are every where. Thanks.
Old Oct 16, 2015 | 06:18 AM
oldspackrat's Avatar
I have 'a 66 98 I'm parting out. Here are a couple switches, not sure if they're the same as a cutlass? I have pulled the switch & can get better pix later if needed?
Scott
Old Oct 16, 2015 | 04:47 PM
sortasane's Avatar
detent switch
Hey, the switch I need is the round aluminum switch next to your voltage regulator on the fire wall. It has a linkage to the carb and on to gas pedal. It should have two wires on it. Let me know how much you want and I want it. My phone is 864-910-6591. Ask for Ted. Thanks
Old Oct 16, 2015 | 04:54 PM
Not to be a fly in the ointment, the 66 switch serves 2 functions unless the 66 is a manual transmission. 1st function is the switch pitch torque converter and the second is passing gear. There are 3 wires, 1 power and the other 2 plug into the trans.
Old Oct 17, 2015 | 04:35 AM
sortasane's Avatar
no torque
Mine only has 1terminal on the trans for detent,no variable torque converter
Old Oct 17, 2015 | 05:21 AM
So your trans is not the original 2spd?
Old Oct 17, 2015 | 05:54 PM
sortasane's Avatar
hard to believe...
I know it is hard to believe but my paperwork says this one had the high compression 330 with a factory TH 400 and a 317 limited slip rear end. The column indicator is for a three speed.
Old Oct 17, 2015 | 06:00 PM
sortasane's Avatar
I will pay...
I will pay for the shipping if you like.
Old Oct 17, 2015 | 07:12 PM
Even the T400 in that year had a variable torque converter although it normally came with a 400 instead of the 330.
Old Oct 17, 2015 | 08:24 PM
I will try to grab the switch tomorrow & make sure it is in good condition & call you.
Thanks.
Old Oct 18, 2015 | 05:13 AM
sortasane's Avatar
m!suderstanding
Sorry. I didn't mean to imply that you couldn't get a two speed with a variable pithch. I just have the kind of odd mix of the three speed with a single pitch converter.
Old Oct 19, 2015 | 07:05 PM
Here are a couple pix of the switch assembly. Take a look & let me know what you think or I'll try to call you tomorrow.
Old Oct 20, 2015 | 11:53 AM
sortasane's Avatar
yes please...
Yes I wanted the switch if you aren't way over priced on i it I want it as soon
as you can get it to me. Just let me know . Thank you Ted Williams
Old Oct 23, 2015 | 07:27 AM
Ted,
I called your number & voicemail is not set up? Call me when you get the chance?
Thanks,
Scott
c. 317-727-7041
Tedisthebestkingintheworl
Jun 19, 2014 10:13 AM
jerseyjoe
May 5, 2011 06:49 AM
arodenhiser
May 19, 2010 01:03 PM
69 Cutty
Aug 24, 2006 08:16 PM
