detent switch
I have 'a 66 98 I'm parting out. Here are a couple switches, not sure if they're the same as a cutlass? I have pulled the switch & can get better pix later if needed?
Scott
Scott
detent switch
Hey, the switch I need is the round aluminum switch next to your voltage regulator on the fire wall. It has a linkage to the carb and on to gas pedal. It should have two wires on it. Let me know how much you want and I want it. My phone is 864-910-6591. Ask for Ted. Thanks
Not to be a fly in the ointment, the 66 switch serves 2 functions unless the 66 is a manual transmission. 1st function is the switch pitch torque converter and the second is passing gear. There are 3 wires, 1 power and the other 2 plug into the trans.
hard to believe...
I know it is hard to believe but my paperwork says this one had the high compression 330 with a factory TH 400 and a 317 limited slip rear end. The column indicator is for a three speed.
84oldsDelta88
Jan 19, 2010 11:04 AM
