64 Starfire carburetor wanted
Old Mar 25, 2015 | 12:47 PM
jensenracing77's Avatar
Looking for an original 4 bbl carb for a 64 Starfire.
Old Mar 25, 2015 | 01:50 PM
rocketraider's Avatar
Oldsdruid
Eric, what you're going to run into here is that 4GC had an aluminum ID tag attached under one of the airhorn screws. After 50 years and untelling how many rebuilds, the ID tag is all but guaranteed to be gone. So there may be no way to positively ID a 4GC as a 1964 carb much less Starfire application, unless someone has one with tag intact.
Old Mar 25, 2015 | 02:10 PM
Oldskeeper's Avatar
Eric, is that for a non A/C car or air car, carbs are different.
Steve
Old Mar 25, 2015 | 02:17 PM
Charlie Jones's Avatar
Phantom Phixer
In the 1972 Olds chassis parts catalog the same 4 barrel carb is listed for 1959 thru 64 except F-85 #7016332
Old Mar 25, 2015 | 04:13 PM
I do not know if it is an A/C car yet. We would be willing to take any that are the correct type. I had one for a 62 since 2002 and just sold it a week before I found out my buddy needed one, lol. We can not find a float of it anyplace. Do you know where to find one?
Old Mar 25, 2015 | 06:31 PM
Phantom Phixer
All 58 thru 65 Olds 4 barrel carbs use the same floats . According to the parts book . #7011945 for primary side and #7012148 for secondary.
62 thru 65 Chevy 409's with single 4 bbl also use the same floats .
Hope this helps you in your search.
Old Mar 25, 2015 | 06:37 PM
deaddds's Avatar
If you happen to know the tag number, I have quite a few 394 carbs of that range with the aluminum tags still present and will look at them if its that specific an application. Pat
Old Mar 25, 2015 | 06:55 PM
If it is a good core he will likely be interested. What would you want for one?
Old Mar 25, 2015 | 07:01 PM
deaddds's Avatar
Typically a core runs $50. If a very specific numbered carb is wanted and I don't have a back up, usually $100. I have mostly big car stuff both nos and very nice used from 62 to 68.
Old Mar 26, 2015 | 02:12 AM
I will talk to him today and see for sure what he wants to do. Thanks
thegreat'71olds442
May 11, 2015 12:00 AM
roberer
May 9, 2014 08:34 PM
jensenracing77
Jun 2, 2013 12:48 AM
1965zoso
May 23, 2011 06:33 PM
yeahbuddy
Jun 1, 2010 05:38 AM
