Need 2 394 cu in Flat Top Pistons
Old Feb 14, 2015 | 05:24 PM
toyolet23's Avatar
Talking Need 2 394 cu in Flat Top Pistons
Rebuilding a 1961 Olds 394 cu in motor & am in need of 2 original flat top pistons. Piston number=573315. Pm me if you can help. Thanks.
Old Feb 15, 2015 | 10:13 AM
59-59-59's Avatar
What part number is on the inside of the piston?? If it is 583967, I have them
Old Feb 15, 2015 | 11:09 AM
toyolet23's Avatar
Numbers are 573315. Still looking.
Old Feb 23, 2015 | 05:22 PM
toyolet23's Avatar
Still need 2 of them.
Old Mar 2, 2015 | 07:43 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I have 2 original 394 flat tops with #381423 cast inside. They came with a bunch of parts 62 Starfire parts I got. They're definitely o.e. GM.
Old Mar 3, 2015 | 11:06 AM
toyolet23's Avatar
PM sent
Old Mar 4, 2015 | 02:16 PM
copper128's Avatar
Lt. Buzzkill (ret.)
PM replied, email sent.
Pics attached
EDIT: For future reference, the first 2 pistons are NOT what the OP needs. His pistons are completely flat on the top. No valve reliefs, nub or anything else. I added the pic he sent me. He's looking for pistons like the one in the last photo.
Old Mar 4, 2015 | 05:22 PM
jminor1961's Avatar
61 pistons
Hello
I am Rebuilding 61 starfire and am rebuilding the motor
I had to replace the pistons I will check and if the are the same.
my motor is 394 10:25 to 1 330 hp your should be 10:00 to 1
and 325 hp if they work you can have them
jim
Old Mar 4, 2015 | 05:41 PM
toyolet23's Avatar
The pistons I need are completely flat on top no indentations. Will try & post a couple of pics. jminor1961 I am interested as long as they are flat tops. Don't know how this happened but one of my piston pics ended up in copper128 attachments above it is the third one, top of piston is completely flat Thanks copper128 for posting as I can't get my pics to upload.
Old Mar 5, 2015 | 01:36 PM
jminor1961's Avatar
Hello
The number on the inside of the pistons is 573315
call me if you can use them 952-475-0153
jim
Old Mar 5, 2015 | 02:07 PM
toyolet23's Avatar
Those are what I need, will be calling you.
Old Mar 24, 2016 | 12:29 PM
Don Scherrer's Avatar
381423 Pistons
Pics attached
I need the 381423 pistons
cdrod
Nov 30, 2014 08:25 AM
Magna86
May 25, 2014 02:24 PM
Al2011
Feb 29, 2012 06:49 AM
MDchanic
Apr 23, 2011 08:19 PM
Jamesbo
Jan 21, 2010 05:23 AM
