Power Antenna Repair Specialist or replacement?
Old October 31st, 2014, 03:17 PM
Southbayolds's Avatar
Anyone out there know of a reputable power antenna repair specialist or has a working replacement power antenna for sale? I am in need for my '66 Old's 98.
Thanks!
Ross
(310) 318-4012
Southbayolds is offline
Old November 4th, 2014, 03:28 PM
crimsoncolby's Avatar
If you do find somebody who does this work, let us know. Personally, I have two Tri-band power antennas from the 70's that won't move up or down; although the motors work. Seems that's always the case from the ones I've pulled. On mine, there is a nylon cord inside that acts like a drive belt that snapped.
crimsoncolby is offline
Old November 7th, 2014, 01:14 PM
Here's some names
Try Curt Parker in Berryville, VA - (540) 323-1499 (that's who I am using to fix my antenna)
or from Hemmings - Power Antenna Rebuilding - Jack (317) 791-0688
Good luck!
Ross
Old November 9th, 2014, 06:29 PM
Paladin31's Avatar
Ross please post to this thread how your rebuild turns out, good info!
Brett
Paladin31 is offline
Old November 9th, 2014, 08:21 PM
GM Enthusiast
OLD SKL 69's Avatar
Try contacting Barney Eaton at 512-869-5114. He rebuilds power antennas for Buicks from the 60's to the 80's. Highly recommended. He also taught me how to rebuild the power antenna for my 85 Riv and it works great.
I'm sure he could help you....I would not think that the antenna in your Olds is really any different from their Buick sister models.
OLD SKL 69 is offline
Old November 10th, 2014, 01:58 AM
Yellowstatue's Avatar
The nylon cord is attached to the top section of the mast and is serviced as one piece. After the mast is removed from the motor, unscrew the top piece (static ball) from the top section and slide the piece out and replace. Nylon cord then feeds into the drum, under the little clutch,(remove clutch, don't loose little ball bearings, and tension spring) round and round. Replace clutch, adjust carefully, bench test. Be careful not to break the soldered connection inside the mast tube. Use white lithium to assemble.
Yellowstatue is offline
curtis mayfield
February 21st, 2023 07:13 AM
BlackGold
May 15th, 2022 05:27 AM
navvet
December 11th, 2013 12:13 PM
super88
July 19th, 2008 01:46 PM
conroyboy
August 28th, 2006 07:23 AM
Quick Reply: Power Antenna Repair Specialist or replacement?
