Wanted 3:90 gear for 69 o type
Old Oct 25, 2013 | 07:39 AM
wildcatmom's Avatar
I'm looking for anything 3:42 to 3:91 that will fit in our 69 o type differential. Good used or new. Thanks!
Old Oct 25, 2013 | 08:50 AM
oldsmobiledave's Avatar
Fyi
FYI there are no gears in between the 3.42 and the 3.91 and you will also need the correct carrier to run them.
Old Oct 25, 2013 | 10:02 AM
507OLDS's Avatar
The GM 3:42,3:91,4:33,4:66,& 5:00 gears use the GM #588 or GM #672 posi carrier.
The #588 is for 28-spline axles. The #672 is for 31-spline axles.
The Richmond gears(now unavailable)3:42,3:90,& 4:10,are made for the GM #671 posi carrier,which is the original carrier for the 3:08 & 3:23 gears. These gears will also fit the new/aftermarket carriers that are available.
Gears are the missing piece of the puzzle for a lot of people.
Old Oct 25, 2013 | 11:32 AM
wmachine's Avatar
Trying to remember member
That's pretty interesting. So if I'm starting with a SF 3.23 posi and want to go with steeper gears, I'm better off *not* getting the #588 or #672 carrier?
Old Oct 25, 2013 | 11:35 AM
507OLDS's Avatar
Correct. Unless you find a set of GM gears.Then you will need the 588 or 672 carrier.
The big thing is to find the gears first.
Old Oct 25, 2013 | 12:17 PM
wildcatmom's Avatar
Sorry, I meant 3:42 or 3:90, 3:73 would have been nice but I don't think that's an olds option.
Old Oct 27, 2013 | 08:56 AM
4-ever-olds's Avatar
I have a set of used 3.90 gears from a GM 12 bolt. I bought them with the intent to install in my Olds but never got around to it. I don't know much about the gears other than the guy I bought 'em from said they would work. Maybe 507Olds can shed some light on these and if they'd work for you....
oldsmobiledave
Jan 5, 2014 12:33 PM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Nasty455
May 4, 2013 04:26 AM
drjr56
Sep 9, 2012 08:05 PM
John McGraw
Oct 3, 2009 12:17 PM
