Rear Window Trim piece
Need the rear window inside corner plastic piece that sits above the package tray. Need the drivers side corner piece. Unfortunately it broke when I took out the package tray.
d1
d1
AL
You talking about these?? (see pic below of a couple from a Cutlass S body style...Supremes are different)...commonly referred to as "Package Tray Corners" or "Eggshells" (self explanatory as you found out).
PM me if you are looking and figure out what one is worth. You don't want to crank down the screw to hold these in...if they don't crack they can still distort over time from excessive screw pressure and heat/sun.
You can paint the thing or leave it in the "period correct" psychodelic '60's, Haight Ashbury all-natural plastic look like the one on the left
I sort of like the look.....leaves no doubt about what era these cars were built in.
There's one on ebay at this time
Dang, it says for Supremes - a different part
http://www.ebay.com/itm/70-72-Olds-C...ded56a&vxp=mtr
maybe that seller has other parts
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
