Wanted: gears
Old Dec 4, 2011 | 06:44 PM
alek72us's Avatar
Olds Dreamer
Wanted: gears
Wanted: 4.10/4.11 gears for 8.5" -10bolt for a 72 olds.
thanks
alek
Old Dec 4, 2011 | 10:38 PM
Rickman48's Avatar
Those 3:73's monaz has, would be real tempting, since 4:10's were aftermarket only - never factory, and probably hard to find, used.
Olds factory had 3:42, 3:90 and 4:33's.
Aftermarket had 3:55, 3:73 and 4:10's.
Old Dec 5, 2011 | 06:50 AM
507OLDS's Avatar
There is no 3:55 for the 8.5" 10-bolt,only the 8.2".
The factory gears are 3:42,3:73,and some trucks had 4:10's.The aftermarket has both 3:90 and 4:10.
Old Dec 5, 2011 | 08:19 AM
Rickman48's Avatar
'From Olds' meant an Olds option, as on the order sheet.
Old Dec 5, 2011 | 12:38 PM
alek72us's Avatar
Olds Dreamer
I don't need olds 4.10s im just seeing if anyone has any aftermarket laying around. i know alot of people get a car that has 4.10 and they take them out to go back to a more driving gear. so seeing if anyone has any laying around. i will also take 3.90.
Old Dec 6, 2011 | 10:09 AM
jhoppeolds's Avatar
I've got a set of Richmond 4.10s still currently in a '73-'77 Cutlass rear end. I'd be willing to seperate them out for $100 plus the shipping. Look good as far as I can tell with them still in the housing.
Old Dec 7, 2011 | 07:01 AM
rptw32's Avatar
What carrrier do you have in yours now ? Makes a difference as to
gear set based on carrier . Olds had 3 different carriers those years.
I have a BRAND NEW set 4.10 Richmond gears for the 671 carrier
( Olds - 3:08-3:23 carrier. )
PM me if interested .
Rgds
Old Dec 7, 2011 | 07:11 AM
507OLDS's Avatar
Rob,
He needs gears for the 71-up 8.5" 10-bolt,not the 12-bolt O-axle.Your O-axle gears,however,might be wanted by someone else,as Richmond stopped making that ratio.
Old Dec 7, 2011 | 07:52 AM
alek72us's Avatar
Olds Dreamer
I have a 12 bolt o axle. but its not a posi and the gears are not what i wanted. i didnt want to break the type o axle so i'm using a 10 bolt posi which shall be fine with what i'm doing with it.
I have found some 4.11 gears. thanks everyone for helping me out.
Old Dec 7, 2011 | 08:34 AM
507OLDS's Avatar
I would use the 71-72 8.5" 10-bolt anyway.It is correct for your car,and the parts are plentiful & cheaper.
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
idaholc
Apr 13, 2009 01:33 PM
bbolds442
Mar 27, 2008 12:35 PM
